sms app is outside of screen cant send sms right now.. quick fix?
Hi. i can't send sms right now..the app is too far right outside of the screen, how can i fix it quick? Need to send a text! thanks!
How do i fix popups, buttons that are outside of the screen sometimes? I love the phone.. But i need to come up with a universal solution to this. An universal solution so all apps fit the phone screen maybe? Thanks
i searched:
https://wiki.mobian-project.org/doku.php...ale-to-fit
What's the scale-to-fit???
5 of 5 Points, fully optimized ? I would say 4 out of 5? Because of the scale..
Edit: I fixed not seeing the button with unlocking the screen rotation and rotating the picture.
(06-01-2021, 12:28 PM)temp0rary Wrote: Hi. i can't send sms right now..the app is too far right outside of the screen, how can i fix it quick? Need to send a text! thanks!
i searched:
I experienced this issue as well with yesterday install of 20210517 image. All I had to do was update & dist-upgrade and problem disappeared. Sometimes I see some hiccups in scaling but all can be solved by rotating to wide and back.
Scale-to-fit is fix for apps not optimized for mobile screen, for example Evolution (You still need it to import contacts). It is simple command you run in terminal and app tries to fit PinePhone screen (not successfull everytime, but it works somehow). However I had to use it only for contacts import. From then no need to do scale-to-fit for me.
Ok, thanks for the answer.. yeah. It's small issues.. Overall everything works good in my opinion. It's a working phone. It should be more beefy in the future though when it comes to capacity/specs.. Other then that.. Sweet phone!
  OpenTTD game - Error: no usable screen resolutions found. eugenr 3 6,764 06-23-2026, 01:12 AM
Last Post: Mary_Davis
  Trixie - bring up the On Screen Keyboard manually. grump_fiddle_reinstall 0 1,514 12-23-2025, 04:34 AM
  On-Screen Keyboard Arrow Keys biketool 11 12,287 12-23-2025, 04:25 AM
  How to add an homemade app to the main screen? JChdeL 3 2,559 11-04-2025, 04:13 AM
Last Post: JChdeL
  New Install, apps start but don't show up on screen?! RT3 2 3,735 07-18-2025, 07:56 PM
  mobian phosh on screen keyboard not popping up for Chromium/Electron apps grump_fiddle_reinstall 1 4,728 01-15-2025, 08:08 PM
  Proximity sensor is oversensitive (was "Screen blanks when making call") treebeard 6 10,945 08-05-2024, 06:12 AM
Last Post: baptx
  Quick question abtut sources.list jojuma 1 3,023 06-17-2024, 04:46 AM
Last Post: zetabeta
  Screen auto-rotation sensitivity mdk 0 2,566 12-26-2023, 06:08 AM
Last Post: mdk
  Screen stay black unless power key pressed short freelectro 0 2,685 06-24-2023, 01:55 PM
Last Post: freelectro
