What is the first-time password?
(11-29-2020, 06:54 AM)wibble Wrote:
(11-28-2020, 10:06 AM)Puro Antinori Wrote: This information does not work for me. I this is what I get for uname -a:
Linux pine64-pinephone 5.9.1 #2-postmarketos-allwinner SMP Mon Nov 2 09:26:33 UTC 2020 aarch64 Linux
neither root nor 123456 are the root password or sudo password for user.
So far I was only able to set the disk encryption password, the SSH password, and the ssh user, but I am not able to install anything because I'm missing the sudo or the root password.
If you're using password authentication for ssh it should be the same for sudo. I think PostmarketOS is one where root doesn't have a password you can use
Thank you, that helped. I can use sudo for the pipi user over ssh. In order to execute sudo commands in terminal on the PinePhone itself, I have to do su pipi and then I can use sudo with pipi's password.
  Default password for KDE plasma pine phone Toni 0 8,471 09-14-2025, 06:35 PM
Last Post: Toni
  Clamares password needed with new Mobian installation fauvetan 1 3,346 06-26-2025, 03:00 AM
Last Post: merom
  Turn off password reginaborder 2 3,632 07-04-2024, 01:53 AM
Last Post: Gumur
  SMS not delivered if receiver offline at sending time alpineduck 14 15,464 09-04-2023, 10:38 PM
  Complete noob to the Pinephone 64, cannot set time and date. gordr 11 12,347 06-06-2023, 10:27 AM
Last Post: gordr
  Lost password on second hand Ubports PinePhone? Peter Gamma 6 9,098 04-10-2022, 01:20 PM
Last Post: Peter Gamma
  Pinephone won't let me enter password czgunner 5 9,637 09-07-2021, 08:50 PM
Last Post: TRS-80
  KDE password freeduck 1 3,720 07-31-2021, 12:29 PM
Last Post: jlucas
Question How long does the phone need to be chrarged prior to turning on the 1st time? awsdert 2 5,473 04-30-2021, 01:40 PM
Last Post: awsdert
  PinePhone Pin/password question dgdimick 3 7,933 03-28-2021, 06:32 PM
Last Post: dgdimick
