Let's talk about safety of Pinephone
#31
(10-08-2020, 05:23 PM)Alho Wrote:
(10-08-2020, 09:05 AM)wibble Wrote: Given that 'this problem' is actually several problems there is no single solution. This is a potential long term solution to problem part 4 that Megous identified - the limit on battery discharge rate being lower than the potential power consumption of the device. While it mostly talks about power usage in terms of its relation to temperature, it is equally applicable to how much is being drawn from the power supply.
There is no overheating problem here at all. According to the conventional performance tests of the battery,
the battery can be discharged with a 1C load - and should last at least 54 mins.
I doubt that we can easily put an 1C load to the battery (2.8A) in the phone.
The same performance tests also indicate that the battery can be charged with 1C
which should give it a full charge (0-100% in less than 2.5 hours.
That said, using 1C may wear the battery down faster than using the usual 0.5C
but there is no safety risk involved.
Reference please - it's good news if true, but the datasheet specifies 0.5C for maximum sustained charge and discharge current. Perhaps they're being overly conservative, but I'd like to see some good evidence before declaring it safe to operate at double that.
https://wiki.pine64.org/images/0/04/Pine...2-2750.pdf
You simply have to read the right spec file :-)
Your linked one is for the v1.0 dev phone
The batteries for 1.1 BH and up is here:
http://files.pine64.org/doc/datasheet/pi...cation.pdf
Read §5.1 Conventional performance
Good find
Thanks - link in the wiki Battery section corrected so nobody else makes the same mistake ;-)
Doesn't the Lithium Ion battery itself have some physical circuitry that protects things like shortcuts, over-charges and heats up and expands the battery, irrespective of software, and catches fire?
Yes, it does have such a safety circuit. It is described in the spec sheet.
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 236 12-04-2025, 08:07 AM
Last Post: WhiteHexagon
Star Selling my Pinephone Pro Explorer Edition zheyon 2 3,027 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 476 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 436 11-18-2025, 03:07 PM
  Pinephone visibly losing power while plugged in Hiraghm 7 4,711 10-21-2025, 10:38 PM
Last Post: Anthona
  Pinephone boot. Richy_T 8 4,587 10-21-2025, 12:12 PM
Last Post: Richy_T
  How can I record video on a Pinephone? kk22 22 15,438 10-08-2025, 01:29 PM
  Does PinePhone support long-term battery health optimization? roseblack 5 1,430 10-06-2025, 09:05 PM
  iso pinephone for sale (USA) elwoodb25 0 3,883 09-24-2025, 09:25 PM
Last Post: elwoodb25
  Why projects like PinePhone matter – feedback and encouragement Gary2003 13 18,344 09-16-2025, 01:13 PM
Last Post: Gary2003
