New Mobian Pinephone
Just got my phone in yesterday.
I got it fired up and charged. Connected to my wifi.
I know this is a work in progress, but my battery seems to last less than an hour.
I tried to look at the software updates, and it just has a spinning ring or freezes.
What's my next step?
(03-11-2021, 04:07 PM)czgunner Wrote: What's my next step?
 This is a good guide (assuming you have the mobian ce edition):
https://blog.mobian-project.org/posts/20...pam_issue/
Cheers!
Perfect. Trying that now. Thanks!
The software tool was broken for me when I first installed it back in January. Command line updates with "full-upgrade" fixed that.
Also possible that something is causing a massive CPU load issue. You may want to look at it to see if things are running idle. "top" over SSH for me is always only a small 1/10th of a percent CPU usage with the screen off.
I do mostly keep the radio off for most of what I'm doing (docked) but I have run Podcasts while clearing the snow outside w/ radio enabled and it's clearly not even close to my Android but should last more than an hour of actual use.
Got the update installed. Seems much more smooth. Also, the battery seems to be better. Charging now. Thanks for all the help!
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 77 44,915 10-27-2025, 10:19 AM
  cryptocurrency on mobian/pinephone biketool 35 59,506 10-08-2025, 06:21 AM
  Mobian MMS/SMS text problem bcnaz 16 28,041 09-15-2025, 02:42 AM
Last Post: georgegohl888
  XLibre for Mobian Hiraghm 1 2,239 06-30-2025, 01:38 AM
Last Post: Haroldkent
  Axolotl on PinePhone / Mobian arno_nuehm 223 281,959 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 2,024 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 2,590 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 3,057 05-06-2025, 02:19 AM
  mobian calamares fail merom 2 3,030 04-29-2025, 02:10 PM
Last Post: mdk
  Pinephone seems tobe using 4G data instead of Wifi data grump_fiddle_reinstall 7 5,254 02-20-2025, 02:47 PM
Last Post: puffchumpy
