Linux mobian 5.11-sunxi64 -> GREAT! ... or not?
(03-08-2021, 11:08 AM)scholbert Wrote: In the end two things with the new 5.11 kernel, that drive me nuts:
- modem got lost after sleep (this is reproducable, if i switch back to 5.10 it's gone)
- jitterentropy service goes mad or hangs and gives 100% system load (same here, reproducable, if i switch back to 5.10 it's gone)
Anyone else observing these issues.
Hi scholbert,
Yes I'm seeing 100% CPU on jitterentropy with 5.11 as well. Not good! Also seeing 100% on another core with systemd-devd, so that's two cores fully consumed. Yuck.
I'm not using sleep (I'm actually running with phosh disabled for a specific project) so I don't know if the modem is getting lost.
Now I have to choose between fast charging via convergence dock (5.11) or having > 50% CPU cores available (5.10). Sigh.
Regards,
GregH
Guys, please contribute your experiences with the power issues on 5.10 in order to try to get it fixed: https://gitlab.com/mobian1/issues/-/issues/176
(03-08-2021, 11:08 AM)scholbert Wrote: ....
Yup - jitterentropy running 100% as soon as I boot.
What is really weird is this happened on a new Mobian I just cooked using the Debos recipes.
My previous Mobian was also cooked via Debos but possibly in January sometime, and update && upgrade since then. As well as all kinds of other experimenting. When I added 5.11 on that I did not have the jitterentropy problem, nor did I have any problem with the modem waking from sleep. (Didn't run the new brew long enough to see if I had any modem waking problems.)
Thanks for the heads up. I noticed the phone hadn't gone into suspend after receiving a call and the battery had drained a lot.
Also have the 100% jitterentropy. I hadn't noticed the modem loss on suspend though I had that issue with Manjaro Plasma Mobile after doing updates so no doubt that explains it as well!
I edited /boot/extlinux/extlinux.conf to boot on 5.10 instead of 5.11 for now.
Just ran an update/upgrade and found that jitterentropy has been updated (to 1.2.1-2) - and the CPU usage is no longer being thrashed on 5.11 Big Grin
i have been seeing 5.11 for while during my updates but it wasn't until today that i am officially Linux mobian 5.11-sunxi64 #1 SMP PREEMPT Thu Mar 11 15:34:35 UTC 2021 aarch64 GNU/Linux when i rebooted after upgrade and issued uname -a. Right away though i am having trouble getting my mini laptop on line via usb tethering Sad .
This is one thing i rely on with Pine phone. Do i need to go back to 5.10? Thank you!
(04-13-2021, 10:19 AM)I had to reinstall  the 20210210 version to get back to the easy and unsecured ways  of doing things. I\m  now back to 5.10 #2.   The USB tethering worked again. Also annoying thing in 5.11 is how  the Bluetooth turns on randomly, which is not right.   HLing Wrote: i have been seeing 5.11 for while during my updates but it wasn't until today that i am officially  Linux mobian 5.11-sunxi64 #1 SMP PREEMPT Thu Mar 11 15:34:35 UTC 2021 aarch64 GNU/Linux when i rebooted after upgrade and issued uname -a.  Right away though i am having trouble  getting my mini laptop on line via usb tethering Sad .
  Mobian MMS/SMS text problem bcnaz 16 35,276 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 995 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 61,512 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 69,410 10-08-2025, 06:21 AM
  XLibre for Mobian Hiraghm 0 2,913 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 326,196 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 2,615 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 3,546 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 4,234 05-06-2025, 02:19 AM
  mobian calamares fail merom 2 3,994 04-29-2025, 02:10 PM
Last Post: mdk
