Mobian phone app update 2-14
I am running mobian-pinphone-phosh-20210202.img
Today I received a system update through the phone GUI and a calling app update. Huge improvement on call quality.
I have postmarketOS edition PinePhone.
(02-14-2021, 11:19 AM)mw4jet Wrote: I am running mobian-pinphone-phosh-20210202.img
Any chance it works with bluetooth calling?
No, bluetooth does not work with calls, making a call though contacts does not work either, you have to actually input the phone number. You can text from the contacts button though.
(02-14-2021, 12:18 PM)mw4jet Wrote: No, bluetooth does not work with calls, making a call though contacts does not work either, you have to actually input the phone number.  You can text from the contacts button though.
Sorry if I don't understand correctly your comment.
Do you mean that a call from the Contact application could not be done ? I'm surprised because I can make a call using the contact list.
gnome-call seems to be broken since last update ...
can't place calls from history or cmdline using gnome-call -l
but as stated, it works from dialpad, it also works from xdg-open (and from the contacts app)
it is a minor issue (it seems to be a memory allocation failure so it should already be fixed by now)
I confirm a problem.
I can't call back from the top menu when I see a "missed call". When I've try to open the Call application a red message said "... : No voice-capable modem".
When I use Contact to make a call, all is working.
On my phone I can go to Text Message from contact page in Contact App, but to make a call, not all contacts work. (I don't want to start calling everybody in my list to know if others work). I did get one to call from the phone icon in the contact app.
My Bluetooth is acting up. I listen to audio on VLC and after 5-7 minutes it just disconnects.
issue seems to be fixed in the last gnome-calls update Smile
(02-15-2021, 05:58 PM)mw4jet Wrote: My Bluetooth is acting up. I listen to audio on VLC and after 5-7 minutes it just disconnects.
That's probably because VLC doesn't prevent the phone from going into sleep. Lollypop does, though.
  Mobian MMS/SMS text problem bcnaz 16 37,061 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 1,393 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 64,272 12-24-2025, 12:11 AM
  No touch KB after update(forky) biketool 4 2,138 12-05-2025, 01:15 AM
  trixie update poll questions suggestions j_s 5 2,553 10-22-2025, 07:14 AM
Last Post: anonymous
  cryptocurrency on mobian/pinephone biketool 33 71,108 10-08-2025, 06:21 AM
  XLibre for Mobian Hiraghm 0 3,172 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 333,693 06-25-2025, 01:19 PM
  VoIP account on mobian dialer j_s 0 2,868 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 3,882 06-07-2025, 03:19 PM
