I am stuck, When in Terminal, unable to enter a password
    The following is on a Pinephone with Manjaro
I get into Terminal and start entering,
I hit the enter icon,
It then ask's for a password.
At the point - no matter what keys are tried, nothing appears on the screen
The only password I have so far is for the lockscreen,
which I changed not long after getting the phone.
I would think it is something basic.
For background, I use Ubuntu on a laptop
(02-12-2021, 01:08 PM)Whio84 Wrote: Hi,
Perhaps try typing "linux" as the password, it might not display anything if its set not to echo the password (ie shows stars for each character input).
I think KDE community edition is based on Manjaro, and might be set up that way (I'm mainly using the openSUSE phosh/ plasma versions and don't have my phone to hand to check right now, sorry
The lockscreen password (PIN) is the user password - use the same digits again.
Hi slate and dukla2000,
Thank you for your replies.
It helped.
It look like when in Terminal and entering the password.
The cursor does not move along the line,
remaining in the same place, with no stars to indicate characters entered.
Whio
  Default password for KDE plasma pine phone Toni 0 8,014 09-14-2025, 06:35 PM
Last Post: Toni
  Clamares password needed with new Mobian installation fauvetan 1 2,782 06-26-2025, 03:00 AM
Last Post: merom
  Turn off password reginaborder 2 3,123 07-04-2024, 01:53 AM
Last Post: Gumur
  How to enter FEL mode? Giddyup 4 10,681 06-16-2024, 06:42 PM
Last Post: Pavlos1
  Boot screen stuck at 'K' because of firmware deleted. poundantisec 9 12,647 08-28-2023, 11:38 AM
Last Post: fxc
  Device Unable To Read MicroSD Card _radv_ 19 17,749 02-18-2023, 02:01 PM
Last Post: _radv_
  resolution stuck at 360x720 tomgtc 3 4,954 04-30-2022, 07:55 AM
Last Post: fxc
  Lost password on second hand Ubports PinePhone? Peter Gamma 6 8,167 04-10-2022, 01:20 PM
Last Post: Peter Gamma
  PinePhone Stuck in landscape (Manjaro Plasma) Ephraimlad 1 3,128 01-04-2022, 05:41 PM
Last Post: jasonriedy
  How to open a terminal on my PC to the PinePhone? amosbatto 2 4,679 12-01-2021, 01:24 PM
Last Post: wibble
