Pinebook Pro has become dead, no lights?
Hi people
I've had a PBP working successfully for a month or so. But now it's dead.
It's sat in an inmoving position, connected to the mains with the barrel charger which I switch on from time to time to top up the battery. It's mostly used for flashing to my pinephone so it's not been used heavily, I also have tried a few OS's so it has been booting from multiple SD cards and the emmc (from original Manjaro) successfully.
Yesterday I flashed opensuse to the emmc (booted and rebooted a few times) and decided it wasn't for me so I flashed Manjaro again but after I tried to reboot it crashed so I had to force shutdown with 10s hold on power button. After that it failed to start up (no lights on front but charger is lit red when plugged in).
After leaving it for an hour or so it started, but after a reboot it went back to dead. And next day that's how it still is.
As it's not been moving it's unlikely to be a loose cable inside so I hesitate to take the back cover off.
Are there any known issues that may help me? Could repeated plugging of mains/SD/USB cause this?VidMate Mobdro
Have you test the reliability of booting ext media with the emmc switched off yet?
Do try that: Manjaro and the U-boot that comes with it seem to cause exactly these symptoms, frequently.
Also reported as of late was a dead wall wart (barrel charger) so if you can, try USB-C.
Quote:My Pinebook Pro is dead and I don't know why and what to do with it. I rebooted it yeasterday, after it refused to work as I was about to do my homework online for a same day class. It went back to dead after a reboot.
Hi John,
Can you use your waranty? How long is it? You should definitely try a USB-C charger so that you could bring up your battery high enough.
  Could Someone Give Advice on Optimising Pinebook Pro for Software Development? Octaviah 0 2,191 08-23-2024, 12:45 PM
Last Post: Octaviah
  [Pinebook Pro] Where to buy a new TFT and how to replace it? openbsd98324 2 2,981 07-23-2024, 07:14 AM
  Pinebook Pro with RK3588? tantamount 28 25,811 07-13-2023, 04:06 PM
  The power of the Star64 vs Pinebook Pro/RockPro64 Starfall 1 3,242 04-17-2023, 05:00 AM
Last Post: lkoini
  PinePower USB-C ports dead nbxmike 1 3,255 01-31-2023, 03:45 PM
Last Post: fxc
  PinePower Desktop USB-C port dead qeek 3 5,073 08-29-2022, 12:33 AM
Last Post: gravedigger
  Could an arm based pine 64 smaller than expected to go with the pinebook zanewiller 1 3,510 04-16-2022, 07:17 AM
Last Post: jiyong
  Could an arm based pine 64 smaller than normal to go with the pinebook zanewiller 0 3,101 04-06-2022, 01:30 AM
Last Post: zanewiller
Star Very Lightly Used PineBook Pro ragnarlothbrok64 4 6,256 01-21-2022, 02:36 PM
Last Post: sascha
  PINEBOOK Pro USB-C Docking Deck compatibility DevonBirch 1 3,583 08-01-2021, 05:13 PM
