Re-do First Time Setup / Location Services Setting (How?)
The "Location" section of the Mobian wiki says:
When the Mobian first time setup wizard asks if you want to send location data to Mozilla Location Services answer “Yes.”
I answered "No" to that question. Sad
I don't know how important it is WRT obtaining location and usable maps, but how do I "undo" my selection? I've searched these forums and also "grep-ed", "locate-ed" and "find-ed" on my Mobian system as best I can to locate the controlling proggy, script or configuration file to no avail or discovery.
Thanks for any help.
I said the same thing to someone else on this forum very recently.
You don't have to answer "yes", it's only important if you need to use things like GPS or a weather application.
Other than that, it has no meaning.
If you need to know where to turn it on or off, settings app → Privacy → Location information service.
[Image: 20201229_16h42m37s_grim.png] [Image: 20201229_16h42m44s_grim.png]
母語は日本語ですが、英語も喋れます(ry
(12-28-2020, 03:31 PM)calinb Wrote: ...
I haven't tried it, but imagine if you delete ~/.config/gnome-initial-setup-done you will get another shot at it all?
Thanks! Completely deleting the file worked. Previously I just changed the file contents from "yes" to "no".
I am interested in the GPS. So far, I have only been able to get a position fix once. The SNR is too weak most of the time, I think. My other Android phones and ages-old Garmin hiking GPS (which lacks AGPS) work great but my Pine Phone is useless for GPS--at this time at least. Oh well. At least I can carry my old Garmin GPS when I need to know my position. Big Grin
  Unable to do initial setup of Weather due to keyboard LibrePhoneUser 2 3,657 07-07-2023, 03:29 AM
Last Post: jojuma
  [solved] Black screen at boot time mdk 0 2,433 01-13-2023, 03:33 AM
Last Post: mdk
  Time is wrong after reboots stucked at 27th august user641 2 3,597 09-08-2022, 01:39 PM
Last Post: user641
  Date & Time-setting app is a very poor design treebeard 6 7,495 07-27-2022, 06:35 AM
  GPS/location services don't work with Maps after Bookworm upgrade Anna 16 21,199 06-13-2022, 02:37 PM
Last Post: wibble
  Header bar date/time vs time-only option Korac 2 3,903 01-17-2022, 10:02 AM
Last Post: Korac
  Mobile network mode setting not saved Zebulon Walton 3 5,801 12-05-2021, 12:12 AM
Last Post: bcnaz
  Setting up Mullvad to run on Mobian Azathoth 2 4,382 11-09-2021, 01:03 AM
Last Post: j4n3z
  Make scale setting persistent 3x5co 2 4,077 10-26-2021, 05:57 PM
Last Post: 3x5co
  22 July 2116 -- wrong Date & Time Anna 7 11,163 07-30-2021, 07:29 PM
Last Post: bcnaz
