EXP Reset pin
Does the reset pin on the EXP connector (2x5 pins) need to be high or low to reset the board?
According to schematic, it is parallel with the reset switch SW2, and therefore should be bring momentarily to LOW.
(05-04-2016, 08:25 PM)martinayotte Wrote: According to schematic, it is parallel with the reset switch SW2, and therefore should be bring momentarily to LOW.
ok. I didnt see that in the schematic, it was just open ended.
thanks
