How to take a screenshot on Phosh?
I tried the "usual" tricks like volume up + volume down, volume up + power to take a screenshot on my PinePhone with Manjaro + Phosh, but it doesn't work. I read on this old blog post that it's now possible, but it doesn't explain the procedure. How can I do it?
(11-14-2020, 08:30 AM)astrojuanlu Wrote: I tried the "usual" tricks like volume up + volume down, volume up + power to take a screenshot on my PinePhone with Manjaro + Phosh, but it doesn't work. I read on this old blog post that it's now possible, but it doesn't explain the procedure. How can I do it?
See this bit of wiki.
I am more used to scrot which does have a delay option.
  • ROCKPro64 v2.1 2GB, 16Gb eMMC for rootfs, SX8200Pro 512GB NVMe for /home, HDMI video & sound, Bluetooth keyboard & mouse. Arch (6.12 kernel, Openbox desktop) for general purpose daily PC.
  • PinePhone Pro Explorer Edition, daily driver, rk2aw & U-boot on SPI, Arch/SXMO on eMMC
  • PinePhone BraveHeart now v1.2b 3/32Gb, Tow-boot with pmOS/SXMO on eMMC
Works, thanks!
Software -> search on screenshot -> GNOME ...looks promising...just installed it
Didn't work for me, "all methods failed". Uninstalled.
It does that .. 60/40 with it working more than 60% of the time...I've not looked at logs nor started any troubleshooting yet
See the wiki for an alternative for taking a screenshot (also scaling but it's there) https://wiki.postmarketos.org/wiki/Phosh#Screen_Scaling
(11-18-2020, 06:22 PM)nbh Wrote: Software -> search on screenshot -> GNOME ...looks promising...just installed it
Same result for me
Pinephone Braveheart
Pinephone Manjaro CE 3/32Gb
Pinephone Mobian CE 3/32Gb
Pinephone Pro Explorer Edition
Same result for me
Same here, does not work at all.
I have rated the "GNOME Screenshot" application as "Not compatible" in my "Which applications are compatible on PinePhone with Manjaro" post here https://forum.pine64.org/showthread.php?tid=12356
Feel free to add your own app review over there if you happen find a half-decent Screenshot application that works on PinePhone with Manjaro Smile
  Where Does Manjaro Phosh Store Its Custom Keystrokes? jakfish 0 1,134 04-25-2023, 09:49 AM
Last Post: jakfish
  Trouble with gnome-screenshot jakfish 0 1,090 04-11-2023, 07:38 PM
Last Post: jakfish
  Backup and Home Screen Tinkering on Phosh jakfish 0 1,134 02-24-2023, 12:56 PM
Last Post: jakfish
  MMS workaround for users with separate APN (works atleast on Manjaro Phosh) alaraajavamma 0 1,408 10-10-2022, 12:53 PM
Last Post: alaraajavamma
Question Running AnBox on Manjaro ARM w/ Phosh? danimations 2 3,163 09-05-2022, 03:42 PM
Last Post: nroth
Question Help installing Snaps on Pinephone running Manjaro ARM w/ Phosh danimations 2 2,493 04-07-2022, 06:02 AM
Last Post: danimations
  Manjaro Phosh Issues Csanderson0313 7 7,290 03-05-2022, 08:23 AM
Last Post: Csanderson0313
  No wifi with phosh image wave22 3 3,156 02-15-2022, 07:25 AM
Last Post: wave22
  How to remove Manjaro Phosh lock screen password? Avisando 4 4,844 10-28-2021, 04:20 AM
Last Post: Avisando
  How can I update Manjaro ARM w/ Phosh using Terminal? danimations 6 5,308 10-24-2021, 11:58 PM
