Latest modem firmware breaks voice calls
after installing the modem firmware from
https://forum.pine64.org/showthread.php?tid=11815
Trying to make a voice call results in an "Unknown error". ModemManager points ad "org.freedesktop.ModemManager1.Error.MobileEquipment.Unknown".
$ mmcli -m 0 --voice-create-call=number=MYNUMBERHERE
Successfully created new call: /org/freedesktop/ModemManager1/Call/1
$ sudo qdbus --system org.freedesktop.ModemManager1 /org/freedesktop/ModemManager1/Call/1 org.freedesktop.ModemManager1.Call.Start
Error: org.freedesktop.ModemManager1.Error.MobileEquipment.Unknown
Unknown error
Any idea what went wrong here? Is there any other firmware build to try?
(11-19-2020, 04:43 PM)bero Wrote: Hi,
Unknown error
Nop : you will find all the commands to make a voice call on my site : https://www.alsatux.com/Pinephone (at bottom).
And you have a syntax error : your forgot the " around the number=MUNUMBERHERE on the first command.
But if someone made the full process using DBus only on CLI, it will be very cool to share here... Wink
$ gdbus call --system --dest org.freedesktop.ModemManager1 --object-path /org/freedesktop/ModemManager1/Call/CALLID --method org.freedesktop.ModemManager1.Call.Start
Command tested !
Unknown error
Hi, I suspect that, as expected, the update reset your modem's configuration settings.
Please carefully re-read this thread: https://forum.pine64.org/showthread.php?tid=11815
You may wish to try booting a more modern OS image with a 5.9 megi kernel, as it should set the relevant settings for you.
(11-19-2020, 10:29 PM)Subsentient Wrote: Hi, I suspect that, as expected, the update reset your modem's configuration settings.
thanks, but that's definitely not the problem -- I'm on the 5.10 megi kernel, git checkout from today.
The problem seems to be that the modem just doesn't register with the carrier anymore after updating the firmware. AT+CREG? and AT+CEREG? show "0,5". AT+COPS=? shows (correctly) the list of available networks.
AT+COPS=1,2,"networkidentifierhere",7 says OK but doesn't connect, AT+CREG? remains at 0,5.
I suspect something broke/disabled roaming - I'm trying to connect to a German cell tower with a Swiss SIM card. This worked before playing with the firmware though.
  Solutions to modem / connection problems Anna 4 7,382 09-13-2026, 07:52 AM
Last Post: idice
  Latest firmware for PinePhone modem! Subsentient 106 247,361 04-03-2026, 08:37 AM
Last Post: baptx
  is there an progam to forward calls and texts to my desktop dallytaur 2 5,588 11-01-2023, 04:55 AM
Last Post: Samurai_Crow
  Article: NuttX RTOS for PinePhone: Phone Calls and Text Messages lupyuen 2 4,713 05-03-2023, 05:03 PM
Last Post: lupyuen
  Article: NuttX RTOS for PinePhone: 4G LTE Modem lupyuen 2 4,953 04-10-2023, 10:19 PM
Last Post: lupyuen
Sad Modem is always visible/connected but stops working after a while dante404 6 8,666 11-08-2022, 09:12 AM
Last Post: dante404
  Downsides of the open-source modem firmware? alpineduck 4 6,916 10-25-2022, 05:28 PM
  Help wanted: location of calls and chatty data files dukla2000 3 8,827 06-13-2022, 02:01 PM
Last Post: israel
  Beta support: MMS on chatty/mmsd on Modem Manager - help/testing wanted! kop316 201 344,751 03-24-2022, 03:16 AM
Last Post: as365n4
  What is the best firmware to use an external screen with? Scary Guy 4 7,544 02-16-2022, 01:36 PM
Last Post: Avisando
