Installing pure-maps from repository
Hi!
I want to install package pure-maps, which some sources say should be updated in alpine repository.
Still "sudo apk add pure-maps" gives "not found" error.
Should I add some additional repository on PostmarketOS?
I would rather avoid installing pure-maps via flatpak.
"flatpak install flathub io.github.rinigus.PureMaps" gives "flathub not found" error.
Please, how could one install pure-maps on PostmarketOS?
Preferrably in "apk add" way, or at least via flatpak?
Currently pure-maps is only packaged on the edge channel.
If you want to switch to edge, change 20.05 to edge in /etc/apk/repositories
If you don't want to switch to edge:
flatpak remote-add --if-not-exists flathub https://flathub.org/repo/flathub.flatpakrepo
I found this, it is somewhat documented in the wiki though it is helpful to know that the command after running sudo setup-apkrepos then hititng e (edit) uses VI commands to remove the comment-out ###s leave edit and save.
https://wiki.alpinelinux.org/wiki/Edge
it would be great to have a full how-to for APK and the package manager.
It would also be nice way to toggle to GUI-browse the alpine packages even those not pinephone specific.
(edit) and for what it is worth now the package manager is hosed, still cant install Pure-maps or do upgrades with all repos uncommented
Thank you very much for your help @TimotheeLF, @biketool !
Your instructions are very helpful, followed them successfully and got PureMaps installed OK.
  Issues after installing latest PostMarket OS with POSH xen314 4 6,997 08-20-2023, 11:18 PM
Last Post: xen314
  maps and navigation Uturn 5 11,436 01-31-2022, 12:49 PM
Last Post: mil
  No shortcuts on homescreen after installing packages jojuma 0 2,699 04-26-2021, 04:08 PM
Last Post: jojuma
