PinePhone Manjaro Edition, does not boot
Exclamation
I just got my pinephone today
but it does not start
(I already removed the plastic between the pins and the battery)
when I press the power button it turn the red light on, then the display get some backlight (but still everything black), and after a 1 or 2 seconds it turn off
and if a press the power button for like 10 seconds, the display does not get any backlight but the red led light gets turned on, and I can turn it off if I press a few seconds the power button again
does anyone knows what happened to my pinephone??
thank you
Smile
I also tried to boot another image from the sd, didnt work
but then I tried with jumpdrive, and it booted
and I installed a new manjaro image, and it is finally working
(11-11-2020, 12:00 PM)vdiazroa Wrote: I also tried to boot another image from the sd, didnt work
 I had the same problem, and installing the latest manjaro via jumpdrive image solved it.
  New PinePhone user issues greenpineuser 8 8,815 12-19-2024, 09:47 PM
Last Post: emilianojay
  PinePhone Beta Edition will not boot from MicroSD card Timothy_Ecc 10 20,213 10-04-2024, 12:01 AM
Last Post: spazz
  Pinephone with KDE plasma - Battery drain when phone is not used Daniello 1 4,303 07-03-2024, 08:38 PM
  link for supported pinephone os manjharo et all penguins_rule 3 5,041 05-09-2024, 03:02 AM
Last Post: Eugo
  systemic issue pinephone penguins_rule 3 5,312 04-02-2024, 11:52 AM
  Boot fails ionmich 6 8,209 11-02-2023, 05:14 AM
Last Post: Uturn
  Manjaro: Settings doesnt open nbh 0 3,474 09-24-2023, 05:25 PM
Last Post: nbh
  Can't get ring on Manjaro Pine Phone thorensjubilee 12 17,740 06-09-2023, 04:40 AM
Last Post: thorensjubilee
  Is Manjaro ARM a Rolling Release? jojuma 4 7,367 05-10-2023, 09:27 PM
  new PinePhone upgrade issue WhiteHexagon 5 8,187 05-09-2023, 04:09 PM
Last Post: WhiteHexagon
