Gnome shell - Mobian Resolution
I have installed Gnome-shell following the instructions from: https://wiki.mobian-project.org/doku.php...vironments
The problem I have is that the Gnome environment is not scaled, so not all the icons appear on the screen and some are overlapping.
I can't find a way to fix the Gnome resolution.
Is there a way to do it?
Thank you.
You'll need to configure the fractional scaling setting in Gnome. It's under the Display menu in Settings.
(10-14-2020, 02:28 PM)canaac Wrote: The problem I have is that the Gnome environment is not scaled, so not all the icons appear on the screen and some are overlapping.
See this post - you may also want to stop the services for phosh, serial usb and packagekit if you notice high cpu usage in idle.
(10-14-2020, 03:36 PM)ThrillGates Wrote: You'll need to configure the fractional scaling setting in Gnome. It's under the Display menu in Settings.
Thanks for the answers. Tonight when I get home I try it.
I could not access the Gnome configuration, since due to the bad configuration of the scaling the options did not appear on the screen.
I found the solution in the post that you indicated. With the following command, the interface was perfectly scaled.
gsettings set org.gnome.desktop.interface scaling-factor 1
  Mobian MMS/SMS text problem bcnaz 16 34,712 06-23-2026, 06:53 AM
Last Post: mehdy
  Mobian image for the PinePhone Korfou 2 919 04-27-2026, 09:57 AM
Last Post: Korfou
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 60,589 12-24-2025, 12:11 AM
  cryptocurrency on mobian/pinephone biketool 33 69,003 10-08-2025, 06:21 AM
  XLibre for Mobian Hiraghm 0 2,858 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 324,993 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 2,558 06-15-2025, 04:19 PM
Last Post: j_s
  Mobian Pinephone Notification LED biketool 2 3,463 06-07-2025, 03:19 PM
  Vivaldi Web browser nearly native for Mobian biketool 3 4,142 05-06-2025, 02:19 AM
  mobian calamares fail merom 2 3,903 04-29-2025, 02:10 PM
Last Post: mdk
