just got blocked on wiki.pine64.org
Hi, I was attempting to edit a page on installing Lazarus and got this error
You do not have permission to edit this page, for the following reason: Your IP address has been automatically blocked because it was used by another user, who was blocked by ‪Abcde‬. The reason given is: Autoblocked because your IP address has been recently used by "Wildfit Review 15". The reason given for Wildfit Review 15's block is "Abusing multiple accounts" Start of block: 08:37, 6 October 2020 Expiration of block: 08:37, 7 October 2020 Intended blockee: 192.168.0.1 You may contact ‪Abcde‬ or one of the other administrators to discuss the block. Note that you may not use the "Email this user" feature unless you have a valid email address registered in your user preferences and you have not been blocked from using it. Your current IP address is 192.168.0.1, and the block ID is #499. Please include all above details in any queries you make.
I don't have multiple accounts, and it has logged my IP address as a local address 192.168.0.1.
I think that someone has messed up.
Well at least it wasn't 127.0.0.1. Smile
(10-06-2020, 02:59 AM)KC9UDX Wrote: Well at least it wasn't 127.0.0.1.  Smile
This is a total guess, but I'm guessing that all the traffic into the wiki goes through a reverse proxy of some kind, and therefore ALL of the users come from the same IP address (the proxy).
oops
Use a VPN for the time being?
Sent from my OnePlus 7 Pro using Tapatalk
Yep, I'm getting the same error message, and it also sees my IP address as 192.168.0.1 . VPN doesn't work, it sees all IPs as 192.168.0.1.
Can't leave a message on Abcde's talk page as we're blocked from editing.
Paging Dr. @fire219 ...
Yeah, the wiki needs to be configured properly to take the reverse proxy into account.
(10-06-2020, 03:31 PM)Avamander Wrote: Yeah, the wiki needs to be configured properly to take the reverse proxy into account.
Admins should also consider that large companies can have thousands of employees all using the same corporate proxy, and then they all have the same source IP address.
Also it is quite common for mobile connections to be NATed through common IP addresses resulting in the same thing.
There are not enough IPv4 addresses to go around and so assuming that two users on the same IP address is abuse is not a safe assumption.
I don't see them assuming that. The length of block was only 24 hours. The actual reason for blocking was spamming, and when they blocked one account, the spammer just made more from the same IP. The length of block clearly takes into account that the spammer may hop IPs, and that other people may be affected by the block.
Anyway, the block is fixed now.
Here you can see how spammers have been flinging themselves at the wiki:
https://wiki.pine64.org/index.php?title=...:BlockList
https://wiki.pine64.org/index.php?title=...g/newusers
Bots. Probably not abnormal these days.
(10-06-2020, 09:49 PM)KC9UDX Wrote: Bots.  Probably not abnormal these days.
No doubt that these are automated bots. Although happening very often, IMHO this still is abnormal Blush
  Ordering from Pine64 website NonPlayableCharacter22 0 981 07-28-2026, 02:07 PM
Last Post: NonPlayableCharacter22
  Has anyone installed Trisquel (linux-libre) on Pine64 RockPro64? libreboy 1 4,894 11-03-2025, 12:08 PM
Last Post: RandB
  Problem joining Discord Pine64 dhdurgee 1 4,991 09-30-2025, 11:44 AM
Last Post: dhdurgee
  SBC Case Builder and Pine64 SBC hominoid 1 5,437 06-13-2025, 03:03 PM
Last Post: hominoid
Star Pine64 Logo Submissions Admiral Snackbar 0 3,691 06-08-2025, 03:00 PM
Last Post: Admiral Snackbar
  Advice on Choosing the Best Pine64 Device for My Use Case? Ingrid 4 6,236 02-28-2025, 01:14 AM
Last Post: stefan_hdb
  Registering my 'nick' on Pine64's IRC network diederik 7 10,040 12-04-2024, 05:44 AM
Last Post: mmonster
  Need Help Choosing the Right Pine64 Board for My Project jacoballen 1 3,852 09-22-2024, 06:28 PM
  [Article] RISC-V Emulator for Pine64 Oz64 SBC lupyuen 2 5,128 07-07-2024, 04:19 AM
Last Post: lupyuen
  Unable to connect to Pine64 IRC channel due to certificate error? Must-Borrow 1 3,607 03-10-2024, 02:43 PM
Last Post: Must-Borrow
