Pinephone speaker buzzing whenever power sent to it
Question
Just recently received my pinephone (also my first phone. not sure if that was a good idea or not yet)
At first the internal speaker was not playing any sound whatsoever. I would click the test speaker button and nothing would happen. The earpiece worked fine so I didn't mind for awhile.
After I got it connected to a cellular network, I decided to open it up to see if I could see anything obviously wrong, like a fly in between the contacts or misalignment or something. My understanding of circuits is high school physics level, so this was probably stupid also.
I didn't see anything, so I closed it up again, and it magically started outputting sound.
However, now both the speaker and the earpiece buzz uncontrollably whenever they're active.
When I select each one to test, even before playing any sound it buzzes. the earpiece is better, but still noticeable.
I've already inspected it for signs of being blown, but I didn't see any obvious holes or uneven vibrating.
So, what do you guys think the problem is, and how should I fix it? Is there a better way to detect a blow?
thanks in advance
[edit]
it is actually quite bearable with the soft case on. I'm still concerned, but it's not longer a big deal.
[edit 2]
Would a high pitched whining noise have anything to do with the battery being drained?
if not then we're back to it being a problem.
(10-03-2020, 10:16 PM)WaldoTheRanger Wrote: Just recently received my pinephone (also my first phone. not sure if that was a good idea or not yet)
thanks in advance
[edit]
[edit 2]
You do not state what distribution you use, so I assume it is postmarketOS stored in emmc. I would suggest that you install a recent distribution of mobian on sdxc card and test sound that way.
Most probably that problem will be gone.
thanks in advance
[edit]
[edit 2]
I'm actually using manjaro off of an sd card for the most part right now. I have tested postmarket on emmc though, and it did the same thing.
for some reason when I used that fonky 13 os multibook sd card mobian didn't play sound at all, and neither did ubuntu (though ubuntu did make that weird whining noise when starting up)
actually postmarket/phosh didn't play anything on that card either. I'm guessing that's broken. I'll try to get some real installs for testing in a bit.
actually it seems to have gotten a lot better after just one stability update on manjaro. I find it bizarre that something like that could be caused by a software bug, but alright.
(10-06-2020, 12:53 AM)WaldoTheRanger Wrote: I find it bizarre that something like that could be caused by a software bug, but alright.
When generating a sound on any computer the software must calculate the precise voltage to be output at least 20'000 times per second.
When there is the slightest fault in that calculation you get distortions or other noise...
I remember back in the mid to late 90s, it was common for many Linux audio drivers to actually put out clicking sounds when the hard disk was being accessed. Lots of things are possible with new drivers on new platforms.
it doesn't get happy
it doesn't get sad
it just runs programs
thanks in advance
[edit]
[edit 2]
I would suspect a hardware problem,
I have one Brave Heart and three PMOS Convergent phones,  even with trying different operating systems
I have never encountered any strange noises coming from any of them.
If anything, I have only had the occasional,  "No Sound" problem.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
  PinePhone Game Thread PixelPaintbrush 30 79,260 06-04-2026, 01:01 PM
Last Post: elinkser
  How can I record video on a Pinephone? kk22 23 21,570 03-25-2026, 12:55 PM
Last Post: baptx
  Pinephone visibly losing power while plugged in Hiraghm 8 6,718 03-09-2026, 07:51 PM
Last Post: Tia Vaughan
  pinephone-support package not upgradable on Mobian fhireman 5 6,943 02-28-2026, 05:49 PM
Last Post: baptx
  Power up a 2nd core? WhiteHexagon 1 781 01-03-2026, 02:24 AM
Last Post: WhiteHexagon
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 863 12-04-2025, 08:07 AM
Star Selling my Pinephone Pro Explorer Edition zheyon 2 4,081 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 1,582 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 1,229 11-18-2025, 03:07 PM
  Pinephone boot. Richy_T 8 6,592 10-21-2025, 12:12 PM
Last Post: Richy_T
