09-16-2020, 04:39 PM
While I'm familiar with Linux (I've been using it since 1993), I'm not familiar with Linux on the PinePhone. How do I know if the PinePhone can see my SD card?
SD Card
09-16-2020, 04:53 PM
df -h
will list all mounted filesystems. if it's not listed in there then it's not mounted by the system
09-17-2020, 10:43 AM
Enter blkid on commandline prompt and you will get some more information. However you will need some imagination to find out which entry might be the SD-Card.
09-18-2020, 04:43 PM
(09-17-2020, 10:43 AM)LinAdmin2 Wrote: Enter blkid on commandline prompt and you will get some more information. However you will need some imagination to find out which entry might be the SD-Card. I figured out which one was the SD card, and installed Mobian. On only a slightly different front, I was THRILLED to discover that OpenJDK was apt-get'able on Mobian. I wrote a very simple test Java Swing program, and it worked. I haven't figured out how to put a launcher icon on the phone's desktop, though.
09-20-2020, 08:43 AM
(09-18-2020, 04:43 PM)AppDeveloper Wrote: On only a slightly different front, I was THRILLED to discover that OpenJDK was apt-get'able on Mobian. I wrote a very simple test Java Swing program, and it worked. I haven't figured out how to put a launcher icon on the phone's desktop, though.https://developer.gnome.org/integration-...es.html.en |
| install iso from sd card to emmc | aular | 2 | 4,054 |
03-11-2024, 10:24 PM Last Post: tllim |
| How To Access the Pine Phone Auxillary microSD Without Removing Card | pinephoneuser22 | 2 | 4,761 |
01-09-2024, 07:02 PM Last Post: britelite |
| SD Card has wrong capacity | AndyM | 11 | 10,799 |
06-11-2023, 12:30 AM Last Post: AndyM |
| Device Unable To Read MicroSD Card | _radv_ | 19 | 20,025 |
02-18-2023, 02:01 PM Last Post: _radv_ |
| SIM Card Slot Terror | thismarty | 4 | 4,999 |
12-21-2022, 05:37 PM Last Post: thismarty |
| MicroSD Card Reuse | _radv_ | 5 | 6,976 |
12-12-2022, 12:26 PM Last Post: chainingsolid |
| Pine Phone Doesn't Recognize New MicroSD Card | _radv_ | 3 | 4,787 |
11-23-2022, 05:19 AM Last Post: _radv_ |
| SIM Card Install | pineme | 4 | 9,321 |
06-10-2022, 03:15 AM Last Post: rocket2nfinity |
| SIM card slot not working | dekrets | 2 | 5,091 |
02-12-2022, 11:09 AM Last Post: dekrets |
| I just got to find phone in my sd card won't read | Tyro | 5 | 10,673 |
11-15-2021, 01:11 AM Last Post: alexenwaston |
