Rock64 No Audio - Solved
I had posted a thread recently requesting assistance to get ayufan Linux configured to support analog (sound) audio from the internal 3.5 mm A/V (headphone) jack. There were apparently a number of Rock64 users interested in this discussion, but there were no respondents offering any suggestions.
Since then, I came across an excellent document detailing alsa configuration that lead me to implement the following solution in that I can now obtain audio from the Rock64's 3.5 mm headphone jack.
sudo nano /etc/asound.conf
defaults.ctl.card 1
defaults.pcm.card 1
defaults.pcm.device 0
(Control-X to save file)
Note that this configuration has only been tested on stretch-minimal-rock64-0.6.15-175-arm64 but should work on all current ayufan images.  It does not add a volume control to alsamixer, so you'll have to do additional configuration if your application requires a volume control.
Bill, WA8WG
Thanks for writing this down, I did a similar config back when I got my first prototype board and testing the DAC audio board as well. I think librelec also has a more advanced config with soft volume controls etc...
Thanks for posting this. I am struggling to get sound out of the cinch outputs on the DAC addon board.
Could one of you post a config, that is supposed to give me sound out of the cinch outputs?
I am currently using this image:
rock64@rock64:~$ uname -a
Linux rock64 4.4.103-rockchip-ayufan-164 #1 SMP Sat Jan 6 11:15:18 UTC 2018 aarch64 GNU/Linux
rock64@rock64:~$ aplay -l
**** List of PLAYBACK Hardware Devices ****
card 0: HDMI [HDMI], device 0: ff000000.i2s-i2s-hifi i2s-hifi-0 []
  Subdevices: 1/1
  Subdevice #0: subdevice #0
card 1: I2S [I2S], device 0: ff010000.i2s-rk3328-hifi rk3328-hifi-0 []
  Subdevices: 1/1
card 1: I2S [I2S], device 1: ff010000.i2s-snd-soc-dummy-dai snd-soc-dummy-dai-1 []
  Subdevices: 1/1
card 2: SPDIF [SPDIF], device 0: ff030000.spdif-dit-hifi dit-hifi-0 []
  Subdevices: 1/1
rock64@rock64:~$
Google Translate :
I tried that way with "xenial-minimal-rock64-0.6.22-188-armhf" and "xenial-minimal-rock64-0.6.22-188-arm64", but I did not hear any sound. why?
その方法を"xenial-minimal-rock64-0.6.22-188-armhf"と"xenial-minimal-rock64-0.6.22-188-arm64"で試しましたが、音が出ませんでした。何故?
(02-28-2018, 03:54 AM)pine3228 Wrote: Google Translate :
I've good results following wbecks's solution (debian stretch mate 9.3, 4.4.112-rockchip-ayufan-189).
Here is my list of packages relating to alsa (I don't know which or if any is necessary)
alsa-utils
libao-common
libao4
libasound2
libasound2-data
libasound2-dev
libasound2-plugins
libmatemixer0
libmatemixer-common
libopenal1
pulseaudio
I use VLC 2.2.7.1 to play sound files, setting Audio/audio device to I2S Analog stereo
The output is strong enough to drive a true Sennheiser headset (4 - 400 ohms)
Hope that helps...
alsa-utils
libao-common
libao4
libasound2
libasound2-data
libasound2-dev
libasound2-plugins
libmatemixer0
libmatemixer-common
libopenal1
pulseaudio
Hope that helps...
I installed them, but I did not hear any sound.
Have you tried several headphones ? There are different types of plugs depending on whether there is a microphone or not ...
(03-05-2018, 08:37 AM)ピュテアスは Wrote: Have you tried several headphones ? There are different types of plugs depending on whether there is a microphone  or not ...
My headphones are of a standard 3.5 mm jack. Mike is not attached.
speaker-test
Even when I executed the command, I did not hear any sound.
Sorry for my weird English.
but how to adjust the volume?
I found this on the Change Log for Mainline Kernel 5.5
Quote:And finally rk3328 audio support, sdmmc detection fix and enabled
    of the gpu on rk3399-puma.
Quote:arm64: dts: rockchip: Add RK3328 audio pipelines
The audio pipelines for HDMI and the analog codec are internal to the
SoC, so it makes sense to describe them at that level such that boards
need only enable the respective nodes for outputs they implement.
Signed-off-by: Robin Murphy
arch/arm64/boot/dts/rockchip/rk3328.dtsi | 32 ++++++++++++++++++++++++
1 file changed, 32 insertions(+)
diff --git a/arch/arm64/boot/dts/rockchip/rk3328.dtsi b/arch/arm64/boot/dts/rockchip/rk3328.dtsi
index 31cc1541f1f5..91306ebed4da 100644
--- a/arch/arm64/boot/dts/rockchip/rk3328.dtsi
+++ b/arch/arm64/boot/dts/rockchip/rk3328.dtsi
@@ -142,6 +142,22 @@
+ analog_sound: analog-sound {
+ compatible = "simple-audio-card";
+ simple-audio-card,format = "i2s";
+ simple-audio-card,mclk-fs = <256>;
+ simple-audio-card,name = "Analog";
+ status = "disabled";
+ simple-audio-card,cpu {
+ sound-dai = <&i2s1>;
+ simple-audio-card,codec {
+ sound-dai = <&codec>;
arm-pmu {
compatible = "arm,cortex-a53-pmu";
interrupts = <GIC_SPI 100 IRQ_TYPE_LEVEL_HIGH>,
@@ -156,6 +172,22 @@
ports = <&vop_out>;
+ hdmi_sound: hdmi-sound {
+ simple-audio-card,mclk-fs = <128>;
+ simple-audio-card,name = "HDMI";
+ sound-dai = <&i2s0>;
+ sound-dai = <&hdmi>;
psci {
compatible = "arm,psci-1.0", "arm,psci-0.2";
method = "smc";
2.17.1
How can this rk3328.dtsi file be used to fix Audio on the Rock64 ?
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 5,410 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 25,894 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 15,456 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 16,980 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 4,201 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 9,005 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 10,106 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 9,333 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 4,418 11-28-2022, 02:18 PM
Last Post: Macgyver
  my rock64 dosen't work rookie_267 0 4,520 10-07-2022, 07:50 PM
Last Post: rookie_267
