OpenGL/ES on RP64
I am using Pinebook Pro, but I also think about buying some RockPro or similar SBC. The main purpose would be some server together with some retro gaming. I don't want to use some precompiled image like Lakka or Recalbox, cause I also want to use it as a print server, mpd server etc. So I prefer running clean Armbian or similar up to date distro. And now there is a problem. Does RockPro OS support OpenGL/ES out of the box? Or do I need to mess with building drivers like on Banana/Orange Pi?
Also, is it fine to use RockPro or some RK3399 derivative like RockPi, Orange Pi 4 etc.?
(07-06-2020, 12:27 AM)Wizzard Wrote: I am using Pinebook Pro, but I also think about buying some RockPro or similar SBC. The main purpose would be some server together with some retro gaming. I don't want to use some precompiled image like Lakka or Recalbox, cause I also want to use it as a print server, mpd server etc. So I prefer running clean Armbian or similar up to date distro. And now there is a problem. Does RockPro OS support OpenGL/ES out of the box? Or do I need to mess with building drivers like on Banana/Orange Pi?
PM me your shipping address including phone number and email address, I will provide RockPro64 to you. Panfrost already OpenGL/ES on RockPro64.
Thank you very much, I cannot wait to try it!
Ok, I got it today, so I am just trying to run stella without WM like I do on my Banana Pi. I am not sure yet if it supports OpenGL ES on Armbian, will write later after I will find out something.
Photo Max Resolution Supported by RP64? hoarfrosty 3 4,604 10-24-2023, 09:58 AM
  Flashed SPI, able to ping RP64 but not boot from sdcard/usb korefuji 2 4,750 08-26-2021, 11:41 AM
Last Post: LMM
  control RP64 power on LMM 0 2,840 04-15-2021, 02:59 AM
Last Post: LMM
  RP64 Mounting hole dimensions Wallaby 2 5,862 09-08-2019, 02:46 AM
Last Post: Wallaby
  Rp64 my new gaming station? NightCrawler504 1 4,499 03-25-2019, 10:48 PM
