Mobian screen dims
Question
I have flashed versions from 20200615 to the latest nightly and they all have the same issue on my Braveheart Pinephone. On booting and entering 1234 the ap drawer is presented and then 2 seconds later the screen goes off . I then no longer have access to the phone. I can unlock it again but to a blank screen. Help ?????
Do you have enough power, such as battery charged enough or the charger connected ?
    Some others have had problems attempting to power their phone from their laptop USB port.
Perhaps there is a problem with your SD card, or possibly the image on your card...
      Though if you are able to 'log-in'  it would more likely be a power problem.
(Personally I use Balena Etcher to flash my SD cards (all new cards) and I have not had a bad image yet)
I have the Brave Heart Edition phone as well,  running Mobian also.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
(06-26-2020, 05:39 PM)bcnaz Wrote: Do you have enough power, such as battery charged enough or the charger connected ?
Phone is fully charged. I've used dd and belana and various cards plus todays nightly. Everytime I get the swipe up to login and enter 1234 and i briefly see the ap drawer and recently it looks like a quick flash of a language page and the screen is still lit but very grey near black. I can push the power button to lock and then unlock but the lock screen loks slightly dimmer each time allowing me to enter 1234 but to the blank page.
I can easily flash Manjaro, PmOs using Pmbuild and UB no issues. Just cannot seem to get Mobian to work. I'm game for any way of turning off screen dimming if its possible to access via usb as i have no sim card in and obvs the wifi hasnt been setup yet.
Can you try with the today's nightly and check if the problem is still here?
If that doesn't work, edit the file /usr/share/glib-2.0/schemas/90_mobian.gschema.override AFTER you have flashed the image and BEFORE you first boot into it (by mounting the SD card on you PC) and add the following line right after "sleep-inactive-ac....":
ambient-enabled=false
(06-27-2020, 03:12 AM)a-wai Wrote: Can you try with the today's nightly and check if the problem is still here?
Just using the nightly https://images.mobian-project.org/pineph...627.img.gz didn't make a difference. I tried the following by editing that file before putting the sdcard into the phone and it doesn't dim any more but after unlocking the screen is backlit but a grey colour no images . Really strange. I'm definately willing to try other things as I really want to try Mobian.
Right, so last idea that comes to my mind: remove /etc/udev/rules.d/10-proximity.rules
Maybe your proximity sensor is acting up, it happened before...
(06-27-2020, 03:25 AM)bcnaz Wrote: hmm....
I have had my best results with :   first Debian/Phosh    and now with Mobian.
If you have time on the app drawer screen, go to settings  >  power  > 'automatic brightness' and turn automatic 'off'
You say you have 'no issues' with the other  OSes ?    just Mobian ?
  I am sorry to hear you are have such a frustrating problem just starting up your new phone.
It doesn't give me enough time to get to the settings. I have noticed if i re edit that file and set ambient mode to true that i briefly after unlocking see the app draw before the screen goes grey. If it is set to false i don't briefly see the app drawer. Does that help ???
(06-27-2020, 03:27 AM)a-wai Wrote: Right, so last idea that comes to my mind: remove /etc/udev/rules.d/10-proximity.rules
Bingo ! The above fixed the issue thank you so much.
Spoke too soon. Sad
Screen has dimmed now so i'll go back and add the ambient line and test.
Right I seem to have got it now. I ad to remove the proximity rule and set the ambient mode to false. Then quickly go to settings and turn off auto brightness as the screen started dimming every second. Now the display stays on.
good Smile
can you tell me what's the output of the following command when putting your hand at various distances from the phone (top left area, just above the 4G/wifi icons), say 1, 2, 5 and 10cm:
cat /sys/devices/platform/soc/1c2b000.i2c/i2c-1/1-0048/iio:device1/in_proximity_raw
(just so we can confirm it's the proximity sensor)
(06-27-2020, 04:04 AM)a-wai Wrote: good Smile
1 - 3109
2 - 3024
5 - 2978
10 - 2972
Ok thanks! When you have time, could you please read through https://gitlab.com/mobian1/issues/-/issues/3 and replicate the measurements other people did?
(basically, every in_proximity_* files, both with the stock and custom kernel mentioned in the thread)
This would be helpful in trying to understand what's going on here (no hurry, it won't be solved overnight anyway).
  bookworm vs trixie discussion for mobian in pinephone regular. zetabeta 80 51,045 12-24-2025, 12:11 AM
  Trixie - bring up the On Screen Keyboard manually. grump_fiddle_reinstall 0 405 12-23-2025, 04:34 AM
  On-Screen Keyboard Arrow Keys biketool 11 7,348 12-23-2025, 04:25 AM
  How to add an homemade app to the main screen? JChdeL 3 857 11-04-2025, 04:13 AM
Last Post: JChdeL
  cryptocurrency on mobian/pinephone biketool 35 64,034 10-08-2025, 06:21 AM
  Mobian MMS/SMS text problem bcnaz 16 31,191 09-15-2025, 02:42 AM
Last Post: georgegohl888
  New Install, apps start but don't show up on screen?! RT3 2 2,302 07-18-2025, 07:56 PM
  XLibre for Mobian Hiraghm 0 2,482 06-29-2025, 12:38 PM
Last Post: Hiraghm
  Axolotl on PinePhone / Mobian arno_nuehm 223 299,453 06-25-2025, 01:19 PM
Last Post: anonymous
  VoIP account on mobian dialer j_s 0 2,243 06-15-2025, 04:19 PM
Last Post: j_s
