US SIM Cards not working on Pinephone
I turned my Pinephone on today to find that my SIM card wasn't detected, and I found that my Pinephone is not detecting US SIM cards but after putting in a European SIM card I had it detected it just fine. The 2 distros I was running were UBPorts and Mobian, could one of them have updated the modem firmware causing this issue? I had a US SIM card working just fine 3 days ago but I updated both Mobian and UBPorts also 3 days ago and I wasn't paying attention to the SIM card status.
Edit: It actually appears to work in the factory test but wasn't working in UBPorts or Mobian.
I just got my UBPorts community edition today. The sim card wasn't working. I then noticed that an extra sim card laying around was a bit larger. That one worked. Is it possible that you're using the wrong sized sim card?
I'm using a micro SIM which is the correct size. I put the European SIM on top of my US T-Mobile SIM and its the exact same size.
I think this belongs to the PinePhone forum
My cricket sim picked up and worked fine first try (it's one of the mid-sized sims, I used the sim insert that came in the plastic baggy in the box). I was able to make and receive calls and txts and was getting LTE. After messing with hotspot settings my LTE quit working and I haven't been able to get it back yet :\ This is with the UBPorts edition.
  PinePhone Game Thread PixelPaintbrush 30 79,287 06-04-2026, 01:01 PM
Last Post: elinkser
  How can I record video on a Pinephone? kk22 23 21,584 03-25-2026, 12:55 PM
Last Post: baptx
  Pinephone visibly losing power while plugged in Hiraghm 8 6,720 03-09-2026, 07:51 PM
Last Post: Tia Vaughan
  pinephone-support package not upgradable on Mobian fhireman 5 6,951 02-28-2026, 05:49 PM
Last Post: baptx
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 864 12-04-2025, 08:07 AM
Last Post: WhiteHexagon
Star Selling my Pinephone Pro Explorer Edition zheyon 2 4,082 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 1,582 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 1,232 11-18-2025, 03:07 PM
  Pinephone boot. Richy_T 8 6,594 10-21-2025, 12:12 PM
Last Post: Richy_T
  4G VoLTE calls confirmed working with carrier x dcinoz 17 34,098 10-07-2025, 11:05 AM
Last Post: baptx
