WiFi/BT module, no bluetooth
I received a week ago my Pine64 2GB version with  the WiFi BTmodule and it seems that the Bluetooth doesn't work.
I tried with the Ubuntu image, when I activate the Bluetooth all the other items of the bluetooth menu stays grey even after a reboot.
Did I miss something?
Also, I wonder if the WiFi/bluetooth module I received is defective, one of the connector doesn't slide all the way down,
I checked with a magnifier and it seems there is something metallic stuck in the pin 3 of the 14 pins connector.
same here, though it works with the android image, so it must be something in the ubuntu config or drivers.
although this youtube vid is for the raspberry, It is abt installing extra software on Ubuntu to get bluetooth working.
https://www.youtube.com/watch?v=xOu3s8homi8
I have the same issue. Tried to update everything sudo apt-get install bluetooth bluez blueman but no luck... Anyone with better ideas?
Hi all, I had the same issue and wrote to tllim about it. Apparently, BT on the current Android build was disabled by mistake and functionality will be added back in the next release. I then tested my module with Remix OS and BT actually works.
So for all of you interested to know whether your module is actually working can try out Remix OS first.
What is the difference between WIFI/Bluetooth and WIFI module. If i bought WIFI module, do i need to buy WIFI/Bluetooth as well?
  [split] Better WiFi/BT module? moriel5 3 10,125 05-18-2022, 01:55 PM
Last Post: moriel5
  WIFI/BT Power Supply / VBAT-EXT xalius 3 8,470 08-12-2021, 06:41 AM
Last Post: Luke490
  Better WiFi/BT module? fonix232 20 41,627 08-11-2021, 09:27 AM
Last Post: Jean-Marc LACROIX
  Wifi / Bluetooth Board Update S265 2 7,027 07-30-2020, 04:53 PM
Last Post: S265
Information Howto: Getting Bluetooth (serial console) working on Debian pfeerick 14 46,852 08-19-2019, 04:33 AM
Last Post: Roverius
  Create a WiFi hotspot on Debian 8 JulianM 6 33,353 03-10-2019, 01:02 AM
Last Post: waqasnasir
  Schematics of Wifi/BT module gamelaster 7 16,229 09-11-2018, 02:02 PM
Last Post: gamelaster
  Wireless Module Driver Source code mido2018 0 3,437 08-08-2018, 04:26 PM
Last Post: mido2018
  Installing another WiFi module on one of the buses mido2018 1 5,989 07-22-2018, 07:15 AM
  Unable to activate wifi on Linux smouton 10 24,093 02-21-2018, 09:56 PM
Last Post: dkebler
