05-26-2020, 02:57 PM
Announcing the Mobian project
(05-26-2020, 02:57 PM)parkerwb Wrote:(05-26-2020, 12:30 PM)murak Wrote: Mobian is running on my emmc as of today and works great! Have a look here :)
05-27-2020, 01:13 PM
(05-26-2020, 03:07 PM)devrtz Wrote:(05-26-2020, 02:57 PM)parkerwb Wrote:(05-26-2020, 12:30 PM)murak Wrote: Mobian is running on my emmc as of today and works great! Yes, I used jumpdrive, but I think I read that you can dd as well while booting from SD card. Should be in the wiki. GL!
"- is there already a tool for overclocking it desperately?"
Well in principle you can flash it onto the SD card, boot from that and dd the running SD card to the eMMC.
While that works, I don't think this is a great idea. Maybe you meant something like an installer image (something like the manjaro images for the pinebook), but we don't have anything like that. Apart from that, the installation procedure is in the project wiki and also in the pine wiki
06-01-2020, 08:16 AM
linux kernel 5.7 is out! does it have improvements for the pinephone?
06-01-2020, 09:24 AM
(06-01-2020, 08:16 AM)paju1986 Wrote: linux kernel 5.7 is out! does it have improvements for the pinephone? Yes - should get the thermal devices into the device tree properly.
06-01-2020, 09:49 PM
(This post was last modified: 06-01-2020, 09:49 PM by TimotheeLF.)
Awesome distro, my go to for my pinephone
!Do you think full disk encryption (like on postmarketos) would be feasible in the future or does it require too much work? Would you need an install script in order to enable it since the images we are flashing are prebuilt?
06-06-2020, 08:58 AM
(05-14-2020, 09:46 AM)a-wai Wrote: Dear all,Thank you so much for your work! Off to go reflash with the new image now, and make a donation. -john
06-09-2020, 02:05 PM
I am running the June 07 nightly build from SD card, AND I have done one update.
Most everything I have tried is working pretty well at this point, after the 'update' I am getting a double of all 'incoming texts' NOT a complaint, just thought I would mention that. It was not doing that before the June 08 update ? GOOD NUF for my daily use Thank You !
LINUX = CHOICES
**BCnAZ** Donate to $upport your favorite OS Team
After updates on 10 June I thought I would give Suspend mode another go. So far I have had no problems and it seems to be working - today I got about 6 hours on somewhere over 50% of battery life with phone predominantly idle.
Not sure if it helps but I am trying to be diligent when waking the phone - about 1 second push on power button (i.e. a decent push and hold, not just a flick!) and then wait 10 seconds or so until the clock is updated and the GSM icon is re-enabled. (I think some of my previous hangs were possibly due to over-zealous stabs at the buttons and screen at the wrong time!) Have yet to receive an incoming call or SMS to see if that wakes the phone. Thank you all devs. And also in linux 5.7 is more hw video acceleration apparently.
| Mobian MMS/SMS text problem | bcnaz | 16 | 39,184 |
06-23-2026, 06:53 AM Last Post: mehdy |
| Mobian image for the PinePhone | Korfou | 2 | 1,742 |
04-27-2026, 09:57 AM Last Post: Korfou |
| bookworm vs trixie discussion for mobian in pinephone regular. | zetabeta | 80 | 68,516 |
12-24-2025, 12:11 AM Last Post: Kevin Kofler |
| cryptocurrency on mobian/pinephone | biketool | 33 | 73,468 |
10-08-2025, 06:21 AM Last Post: biketool |
| XLibre for Mobian | Hiraghm | 0 | 3,382 |
06-29-2025, 12:38 PM Last Post: Hiraghm |
| Axolotl on PinePhone / Mobian | arno_nuehm | 223 | 345,243 |
06-25-2025, 01:19 PM Last Post: anonymous |
| VoIP account on mobian dialer | j_s | 0 | 3,044 |
06-15-2025, 04:19 PM Last Post: j_s |
| Mobian Pinephone Notification LED | biketool | 2 | 4,226 |
06-07-2025, 03:19 PM Last Post: KC9UDX |
| Vivaldi Web browser nearly native for Mobian | biketool | 3 | 4,978 |
05-06-2025, 02:19 AM Last Post: biketool |
| mobian calamares fail | merom | 2 | 4,676 |
04-29-2025, 02:10 PM Last Post: mdk |
