Sprint MVNO Support?
The modem company says the modem is certified by Sprint, does that mean it will work? Or will it not work since the PinePhone is probably not registered in Sprint's systems?
Another question whose answer is very important to me. Do any of the distros support disabling 4G on the PinePhone? I'm asking because I really want to use CDMA2000(Sprint 3G).
(05-01-2020, 05:53 PM)vituous Wrote: The modem company says the modem is certified by Sprint, does that mean it will work? Or will it not work since the PinePhone is probably not registered in Sprint's systems?
Sprint is in a state of flux now. Since T-Mobile took over, they have activated B2 1900 on T-mobiles network for Sprint customers. So you should be seeing greater 4G coverage and VoLTE on that band. However, they are taking away B41 2500 completely and dedicating it to 5G NR. Despite complaints, they are currently not planning on keeping LTE on that band, effectively bricking access to that band for all but the Samsung Galaxy S20.
As far as CDMA/EVDO Sprint was sunsetting that network before the T-Mobile acquisition, and T-Mobile is not changing that plan. https://www.reddit.com/r/Sprint/comments...ctivation/
Ubuntu Touch has no way to set 3G/4G/LTE preference. I saw a commit on git to add the capability to select network preference type in ofono but it's not available yet. Some of the other builds don't use ofono, so someone using them will have to tell you if they can.
Okay thanks, that's useful information. Now that I think about though, I think the modem supports CDMA but not EVDO or CDMA2000, so I'd be stuck on 4G anyway since 2G is gone completely with Sprint.
At least in Debian Phosh you can set your preferred connection or even only allow one.
I think in Sailfish that was possible as well.
Ubuntu Touch OTA 12 RC on my Nexus 5 does include the ability to select  2G, 3G, 4G/LTE in cellular settings. Unfortunately, still doesn't separate LTE specifically.
  Does PinePhone support long-term battery health optimization? roseblack 5 1,012 10-06-2025, 09:05 PM
  US Mobile, via T-Mobile, won't support Pinephone Pro - SOLVED, SIMPLY jovval 14 18,176 07-18-2025, 04:24 PM
Last Post: dchang0
  Looking to pay for support. profileyourcity 1 1,891 09-18-2023, 12:25 PM
Last Post: zetabeta
  My customer support experience ionmich 1 2,030 08-15-2023, 03:17 PM
Last Post: fxc
Lightbulb Suggestion: NFC-F / FeliCa Support for next gen PinePhone or board add-on iamauser 0 1,719 03-11-2023, 10:21 AM
Last Post: iamauser
Sad PinePhone carrier support bucnham 2 2,771 12-27-2022, 12:37 AM
Last Post: rocket2nfinity
  pinephone-support package not upgradable on Mobian fhireman 4 5,331 09-24-2022, 08:01 AM
Last Post: dante404
  Carriers do not support PinePhone? rey70 22 23,652 02-07-2022, 09:06 PM
Last Post: bcnaz
  SD nonfunctional, how is support supposed to work? slomobile 6 7,140 01-18-2022, 07:02 PM
Last Post: slomobile
  double tap to wake support bam 5 8,418 11-04-2021, 07:22 AM
Last Post: bam
