accessing sd card from terminal / file manager
once UT is installed on internal emmc, how can you access the sd card?
It should be able to detect and mount normal SD cards. That's at least how it works on other devices, not sure if that already happens on the pinephone.
You can try it. Just make sure your sd card isn't bootable anymore and formatted into a normal FS like FAT32.
(03-17-2020, 03:22 AM)kugiigi Wrote: It should be able to detect and mount normal SD cards. That's at least how it works on other devices, not sure if that already happens on the pinephone.
thanks, in fact sd is still bootable
  file manager vs. SD card laserpyramid 6 13,436 10-18-2021, 03:10 AM
Last Post: acrux
  Copy To SD Card, All I get Is Red Light & Black Screen . . . . NobodyNew1 9 19,386 09-13-2020, 08:59 PM
Last Post: NobodyNew1
  Automount SD card MasterGreenbolt 7 18,659 08-16-2020, 05:40 AM
Last Post: FOSSagent0
  File transfer mode no longer working? Zweitaktmotor 0 3,603 08-15-2020, 07:31 AM
Last Post: Zweitaktmotor
  Is bluetooth lag for A/V playback due to SD card? Cree 1 4,695 08-02-2020, 06:30 PM
Last Post: hiimtye
  Booting from SD card bingo600 1 4,697 06-20-2020, 02:33 AM
Last Post: bingo600
  SIM card not detected AddieDirects 5 12,617 06-12-2020, 04:06 PM
Last Post: Momomentum
  Terminal Preferences unresponsive Foxchild 2 6,178 03-08-2020, 02:00 PM
Last Post: Foxchild
