Linux reboot command dont' restart
I have a problem with the Rockpro64.
I have used a microSD with ARMBIAN like a OS (Kernel 4.4.213-rockchip64) , and the board work good.
But when I try to restart the os with the command reboot of Linux, the os shutdown but it doesn't boot.
I must necessarily turn  off and turn on  the electricity, but this is not possible remotely.
The board is connected to:
- an ATX power supply;
- PCI-E controller whit 6-port (with n.3 hdd  + 1 ssd )
- RTC Battery CR2032
do you have any suggestions?
This (https://forum.armbian.com/topic/3529-rebootshutdown/) might be related. What command are you using to shutdown?
(03-11-2020, 08:06 AM)davide.duca Wrote: ...
IMHO it is not the board, it is the release. For me sudo reboot works fine with
chris@Rpro64:~$ uname -a Linux Rpro64.dukla.net 4.4.202-1237-rockchip-ayufan-gfd4492386213 #1 SMP Sat Nov 23 13:55:47 UTC 2019 aarch64 aarch64 aarch64 GNU/Linux chris@Rpro64:~$ lsb_release -a No LSB modules are available. Distributor ID: Ubuntu Description: Ubuntu 19.10 Release: 19.10 Codename: eoan
Question Which Linux builds enable hardware accelaration? ACE3CGL 1 5,018 07-26-2020, 09:36 AM
Last Post: xmixahlx
Question How to automatically reboot rockpro64 in case it shutdown abruptly ? seaurchin 2 6,460 11-25-2019, 08:46 AM
  RockPro64 not coming online after reboot imapc99 5 12,385 08-04-2019, 01:34 AM
Last Post: imapc99
  rockpro64 4gb dont boot mehdy 6 12,389 05-26-2019, 10:05 AM
Last Post: Nikolay_Po
  Thoughts on Linux OS vs Just Enough Linux Media Boxes buzzmarshall 1 4,564 03-25-2019, 10:29 PM
Last Post: odhinnhrafn
  reboot issue, hangs dkebler 12 29,799 02-13-2019, 08:10 PM
Last Post: Belakor
  7″ LCD Pine64 touch screen + RockPro64 + Linux Impact 0 4,469 02-07-2019, 04:03 AM
Last Post: Impact
  Camera support for linux image in rockpro64 rahulsharma 1 4,972 01-26-2019, 09:48 AM
Last Post: anykey
  Nvidia Linux-32bit ARM drivers on Rock64 Pro gbajson 6 14,595 07-12-2018, 08:02 AM
Last Post: joe2gaan
