My PinePhone won't start. I am giving it away if you want to try and fix
Big Grin
I got my PinePhone a few weeks ago. It worked great for a few hours. I tried changing the OS and all of a sudden, it won't start. I tried doing some of things people mentioned in the forum but it didn't work for me. Now it's just sitting on my desk.
If you want to try to fix and play with it, let me know. I can ship it to you, for only shipping. PM/DM me. Thanks/MS
(03-02-2020, 11:58 AM)mswaleh Wrote: Hi,
Ill take it off you, I tried to send you a PM , but seems like your Private Messages are disabled ?
PM me when you get a chance pls.
Connect to it via serial console. Any USB to 3.3V TTL converter that uses RS-232 for serial communication transmission and adapts to a 3.5mm audio jack will do. From there you should be able to see what the issue is. For an idea on how to connect your computer to a serial console see me post about my experience connecting with a serial console: https://forum.pine64.org/showthread.php?tid=9516.
Post back and let us know what you find out after attempting to boot while connected to the serial console.
Also, remember that the PinePhone will boot both from eMMC and SD. Don't give up so easily, I am sure you can revive your PinePhone.
Cheers!
dustfinger
  Pinephone visibly losing power while plugged in Hiraghm 10 10,400 10-14-2026, 04:20 PM
Last Post: Flymoon
  Pinephone software Csanderson0313 3 2,185 07-10-2026, 02:21 PM
  PinePhone Game Thread PixelPaintbrush 31 89,407 06-11-2026, 02:50 PM
Last Post: elinkser
  How can I record video on a Pinephone? kk22 23 27,290 03-25-2026, 12:55 PM
Last Post: baptx
  pinephone-support package not upgradable on Mobian fhireman 5 9,283 02-28-2026, 05:49 PM
Last Post: baptx
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 1,882 12-04-2025, 08:07 AM
Last Post: WhiteHexagon
Star Selling my Pinephone Pro Explorer Edition zheyon 2 5,586 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 3,210 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 2,607 11-18-2025, 03:07 PM
  Pinephone boot. Richy_T 8 9,080 10-21-2025, 12:12 PM
Last Post: Richy_T
