How to restore factory Debian installation from SD?
Hello everyone,
I've been fiddling with my PBP with the default debian desktop for a while now. I've met some problems because it appears the kernel used is for arm64 architecture, while the userspace is armhf (32-bit arm by default).
This makes hard to build certain software (e.g. buildroot, esp-idf, crosstool-ng...) because installers download the 64-bit version of the sources (following the architecture given by `uname -a`) which then cannot be compiled by the 32-bit gcc.
While trying to work around this limitation I'm afraid I botched my debian installation and now apt doesn't work.
I wanted to start clean again so I prepared an SD with Debian Desktop. I can successfully boot from it, but from there I expected to see instructions to move the installation to the eMMC.
How should I move the installation to the eMMC from an SD booted OS?
https://forum.pine64.org/showthread.php?...6#pid52036
There ya go
Thank you. Obvious in hindsight Smile
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 8 16,721 06-26-2025, 09:20 PM
Last Post: reukiodo
  Pinebook pro won't boot after bootloader installation jwensouls 4 7,319 08-21-2024, 04:17 AM
  Official Debian support moonwalkers 64 112,803 07-08-2024, 01:40 PM
Last Post: Humid Stylus
  Debian on Pinebook Pro u974615 7 10,952 03-31-2024, 10:11 AM
Last Post: u974615
  Fedora 37 installation gswatkins 16 18,574 03-16-2024, 03:09 PM
Last Post: michel_luc
  Pinebook Pro upgrading from the factory image yamsoup 12 15,153 02-22-2024, 04:02 PM
  install debian on pbp jsch 7 11,029 11-22-2023, 04:22 PM
Last Post: TRS-80
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 20,897 09-07-2023, 09:38 PM
  HOW TO create a installation USB with ... (see below) Ice-O-Star 1 3,873 01-06-2023, 01:02 PM
Last Post: DrYak
  My installation guide starting from messed up eMMC Besouro 0 2,955 12-19-2022, 01:01 PM
Last Post: Besouro
