Pine Phone no power up or just somtimes
Any update on this ? @kxpunisher @rk7 I have a similar problem that I describe here: https://forum.pine64.org/showthread.php?tid=9042 (except Linux does not sees the phone when plugged).
(02-07-2020, 10:23 AM)gab Wrote: Any update on this ? @kxpunisher @rk7 I have a similar problem that I describe here: https://forum.pine64.org/showthread.php?tid=9042 (except Linux does not sees the phone when plugged).
Sadly no. I'm still having the same issue. Even without the battery and connected to usb, the phone won't boot.
Here are the messages I get when I connect the phone:
Feb  8 01:48:57 dan kernel: [ 8638.107243] usb 3-13: new full-speed USB device number 8 using xhci_hcd
Feb  8 01:48:57 dan kernel: [ 8638.259937] usb 3-13: New USB device found, idVendor=1f3a, idProduct=efe8, bcdDevice= 2.b3
Feb  8 01:48:57 dan kernel: [ 8638.259942] usb 3-13: New USB device strings: Mfr=0, Product=0, SerialNumber=0
Feb  8 01:48:57 dan mtp-probe: checking bus 3, device 8: "/sys/devices/pci0000:00/0000:00:14.0/usb3/3-13"
Feb  8 01:48:57 dan mtp-probe: bus: 3, device: 8 was not an MTP device
And by the way, the first time I turned on the phone it did boot up, here are the corresponding messages:
Feb  1 12:29:41 dan kernel: usb 2-1.7: new high-speed USB device number 8 using ehci-pci
Feb  1 12:29:41 dan kernel: usb 2-1.7: New USB device found, idVendor=18d1, idProduct=d001, bcdDevice= 5.04
Feb  1 12:29:41 dan kernel: usb 2-1.7: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Feb  1 12:29:41 dan kernel: usb 2-1.7: Product: PINE64 PinePhone
Feb  1 12:29:41 dan kernel: usb 2-1.7: Manufacturer: PINE64
Feb  1 12:29:41 dan kernel: usb 2-1.7: SerialNumber: postmarketOS
Feb  1 12:29:42 dan kernel: usb 2-1.7: USB disconnect, device number 8
Feb  1 12:29:42 dan kernel: systemd-udevd[5635]: 2-1.7: Failed to process device, ignoring: No such file or directory
Feb  1 12:29:42 dan kernel: usb 2-1.7: new high-speed USB device number 9 using ehci-pci
Feb  1 12:29:42 dan kernel: usb 2-1.7: New USB device found, idVendor=18d1, idProduct=d001, bcdDevice= 5.04
Feb  1 12:29:42 dan kernel: usb 2-1.7: New USB device strings: Mfr=1, Product=2, SerialNumber=3
Feb  1 12:29:42 dan kernel: usb 2-1.7: Product: PINE64 PinePhone
Feb  1 12:29:42 dan kernel: usb 2-1.7: Manufacturer: PINE64
Feb  1 12:29:42 dan kernel: usb 2-1.7: SerialNumber: postmarketOS
Feb  1 12:45:13 dan kernel: usb 2-1.7: USB disconnect, device number 9
I really don't know what happened since then, I just hope it's not a hardware failure. And I still agree with kxpunisher that this is not a battery issue.
Which OS are you trying to Boot? I noticed that Postmarket OS can boot up right away, but for Ubuntu Touch, I have to hold the power button for ~20 seconds before it powers on.
(02-03-2020, 05:03 AM)Luke Wrote: Remove the little tab between the battery and mainboard pins.
  Most phones and Laptops I have purchased (New) in the past,  Recommend "charging fully before use"
      * I think the International shipping Laws state this type of battery cannot be charged above a certain amount for shipping safely *
   Not saying this is "THE" problem,  but it could pose A problem when starting a new device  ?
   I did turn my phone on by accident when I plugged in the charger,  so I scrolled through the screens, then turned it back off.
   I am going to charge mine fully before I try it with an SD card....
     I have been waiting since I ordered it back in November,  so a couple of hours is not much longer.
not certain : but seems I read somewhere . . . it does not 'see' the eMMC when plugged in and the battery is removed.... ?
(Maybe I have that wrong ? but, we are not real familiar with this new device)
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
I know what I did, I think. I wrote to EMMC when prompted, and it wasn't an image -- I guess it was an app. But I can't boot now (despite all sorts of shenanigans with charging, battery, no battery) and I get the same type of output with
lsusb
(02-08-2020, 10:56 AM)kop316 Wrote: Which OS are you trying to Boot? I noticed that Postmarket OS can boot up right away, but for Ubuntu Touch, I have to hold the power button for ~20 seconds before it powers on.
I have noted this as well, with manjaro, ub on sd card.    A full 20 second hold to get it to boot.
  Pinephone visibly losing power while plugged in Hiraghm 8 6,462 03-09-2026, 07:51 PM
Last Post: Tia Vaughan
  Power up a 2nd core? WhiteHexagon 1 682 01-03-2026, 02:24 AM
Last Post: WhiteHexagon
  PinePhone sensors - Gyroscope power WhiteHexagon 3 1,397 11-30-2025, 08:07 AM
  Default password for KDE plasma pine phone Toni 0 7,831 09-14-2025, 06:35 PM
Last Post: Toni
  Fix Fake 0% Battery(charged with USB power) Shutdown biketool 0 2,584 04-17-2025, 04:11 AM
  My new phone stopped working. gunnygee 3 4,052 12-12-2024, 01:21 PM
  Pine Phone in Australaa and Telstra tracyanne 2 2,734 12-06-2024, 02:42 AM
Last Post: tracyanne
  Can't complete update of manjaro: wwan0 stays disabled; no phone/text gilford 3 3,604 12-05-2024, 06:42 AM
Last Post: gilford
  2G, 3G still is in phone. Piotr Bujakowski 5 5,703 09-19-2024, 03:49 AM
Last Post: jennybaso
  Looking for the "non-phone" OS wakyct 7 7,892 03-14-2024, 03:51 AM
Last Post: MTXP
