I finally figured out how to get around the screen turning off and on with the current version of sailfish. Looks like the issue is the with the light sensor, I found that it would the screen would turn off less often if I angled it just right into some strong light. I was able to get into the settings and turn off the "Adjust automatically" setting in the "Display" settings. Once that was turned off everything worked as normal.
| Infinite Loading Screen | syrinx | 2 | 6,420 |
11-30-2020, 11:11 AM Last Post: syrinx |
| Date and Time Issues | MarkF | 1 | 4,528 |
10-23-2020, 06:04 AM Last Post: RodneyMyers |
| Lock screen problem? | undo | 5 | 10,400 |
03-03-2020, 05:00 AM Last Post: explit |
For those having issues with the screen turning off
