How do I easily charge the watch?
Hi everybody,
my devkit recently arrived and I'd like to charge it.
This may come as a weird question to some, but how do I charge the watch? I need to hold the case closed with relatively much force for the contacts to remain securely closed. I've tried to put something more or less heavy on it while charging, but that didn't do the trick. Permanently closing the backplate with glue probably isn't a good idea either as I will need to flash it every now and then.
How are you guys doing that?
I leave the case open with the green cable (lower right) connected to the 5V charging pad. More details https://medium.com/@ly.lee/build-and-fla...85e65aebe9
Yeah it's really ugly [emoji3][Image: ccf3ccdb93a3a2e043c67dbc65befe4e.jpg]
(01-11-2020, 06:18 AM)Paranoid Wrote: Hi everybody,
I had the same problem.   I taped the back on but it wouldn't charge because the back wasn't closed tightly.  I had connected it through a DROK USB Meter so I could see if it was drawing current.  I put heavier and heavier books on the watch until it started to charge.  The book that did it was a Linux command reference of over 600 pages.  When the USB meter showed the current had dropped close to zero I knew it was charged.  It took slightly over two hours the first charge.
For charging I used a spring clamp. Seems to work well.
(01-13-2020, 01:24 PM)VMMainFrame Wrote: I put heavier and heavier books on the watch until it started to charge.  The book that did it was a Linux command reference of over 600 pages.
So in the end, your PineTime does run under Linux !   (SCNR)
I originally just balanced a paper weight on it but I'm trying to develop on it now and its useful to charge it and interact with the screen so I cut a couple of tiny clamps on a laser cutter.
[Image: 49413694211_89cf7de84f.jpg]
PineTime glue free charging case
I just use a rubber band.
(01-20-2020, 08:43 AM)PreMis Wrote: I just use a rubber band.
Over-engineering? Probably a little bit guilty here... Big Grin
I used.... an Elastic Wink
[Image: rubber+band.jpeg]
(01-20-2020, 05:11 AM)danielt Wrote: I originally just balanced a paper weight on it but I'm trying to develop on it now and its useful to charge it and interact with the screen so I cut a couple of tiny clamps on a laser cutter.
please post your design files!
  Custom Watch Faces Performance sophiasmith 0 976 01-03-2026, 02:23 AM
Last Post: sophiasmith
  Making watch vibrate using Python from a Raspberry Pi YoungRechnitz 0 1,371 03-27-2025, 03:51 PM
Last Post: YoungRechnitz
  Another stuck watch! Ralpharama 11 10,741 06-07-2023, 09:10 AM
Last Post: Ralpharama
  Update of new watch consistently fails bitreaper 5 8,638 06-01-2023, 02:29 AM
Last Post: feketej
Exclamation Stuck at Infinitime Logo with 18% battery on full charge? PiningFjord 1 3,104 03-13-2023, 05:05 PM
Last Post: PiningFjord
  Whoops! Developing games on this (apparently not Linux) watch. Www 2 4,335 06-26-2022, 07:12 AM
Last Post: Www
Question Open box, upgrade, dead watch? ahaplesshappenstance 5 6,661 06-25-2022, 03:13 PM
Last Post: ahaplesshappenstance
Question What can/can't I do with a PineTime smart watch (sealed)? danimations 7 12,165 04-16-2022, 07:18 AM
Last Post: _slowmanship_
  Another similar smart watch VMMainFrame 3 8,704 09-16-2020, 02:33 AM
Last Post: danielo515
  Similar Smart Watch VMMainFrame 3 9,566 01-18-2020, 07:35 AM
Last Post: Surehand53
