What thermal compound will fit better to the aluminum case?
Hi. Could anyone please suggest thermal compound (tape) to apply to the aluminum case?  Primarily, i am just interested in the tape thickness, but will be grateful for the links to concrete models. Unfortunately i can't measure thickness by myself, the box is running 24/7.
Thanks in advance.
Which case is this question for? Do you have a URL?
  DeskPi case alternative for ROCK64 v1k699 2 13,412 05-29-2025, 06:57 PM
Last Post: ameridroid
  Case for the rock64 that supports the POE hat. o1CRiMSON1o 2 4,704 05-13-2025, 07:32 AM
  3D-Printable Button Pegs for the ROCK64 Aluminium Case CounterPillow 2 9,092 08-04-2022, 01:31 AM
Last Post: Vicky Weimann PhD
Smile wooden case for ROCK64 killor 13 28,730 03-04-2022, 06:56 AM
Last Post: killor
  Assembling the premium aluminum case mlefevre 14 28,490 07-07-2021, 05:50 AM
Last Post: Rocklobster
Heart Best quick/easy way to control case fan speed? idillicah 4 12,366 06-24-2021, 09:14 AM
Last Post: CounterPillow
Lightbulb Mount a HeatSink on the Rock64 using 3M Thermal Tapes MarkHaysHarris777 22 66,088 11-29-2019, 03:14 AM
Last Post: ab1jx
Information Brushless Fan (5v) for Rock64 Clear Case Soft PWM Drive 2N2222 MarkHaysHarris777 7 24,656 07-09-2019, 06:15 AM
Last Post: merwone
  Rock64's temperature while being in aluminium case _zernok 3 9,645 06-23-2019, 08:00 AM
Last Post: rasputin
  Fitting Rockpro64 inside Pinebook case made2hack 2 6,659 02-20-2019, 01:27 AM
Last Post: made2hack
