Android 9 SDK CRC errors
Hi!
I get a CRC error when extrating the android 9 SDK. MD5sum fits the one from the website.
Even gzrecover can't help. Is it really broken or some incompatibility (Debian Buster)?
Kind regards
(12-31-2019, 02:51 PM)ddimension Wrote: Hi!
Kind regards
File can be extracted with pigz.
Kind regards
Didn't work for me. MD5 checksum is okay. Filesystem is ext4. Gunzip, 7z, unpigz all fail:
xxx@zzz:/media/build_envs/rockpro64/sdk_android9$ md5sum ROCKPro64_SDK_android9.0.tar.gz
3cebeefd1a873beeec149148a785d92e  ROCKPro64_SDK_android9.0.tar.gz
xxx@zzz:/media/build_envs/rockpro64/sdk_android9$ mount | grep build_envs
/dev/sdb1 on /media/build_envs type ext4 (rw,nosuid,nodev,relatime,data=ordered,user)
xxx@zzz:/media/build_envs/rockpro64/sdk_android9$ df -h | grep build_envs
/dev/sdb1       493G  168G  300G  36% /media/build_envs
xxx@zzz:/media/build_envs/rockpro64/sdk_android9$ gunzip ROCKPro64_SDK_android9.0.tar.gz
gzip: ROCKPro64_SDK_android9.0.tar.gz: invalid compressed data--crc error
xxx@zzz:/media/build_envs/rockpro64/sdk_android9$ 7z x ROCKPro64_SDK_android9.0.tar.gz
7-Zip [64] 9.20  Copyright (c) 1999-2010 Igor Pavlov  2010-11-18
p7zip Version 9.20 (locale=en_US.UTF-8,Utf16=on,HugeFiles=on,4 CPUs)
Processing archive: ROCKPro64_SDK_android9.0.tar.gz
Extracting  ROCKPro64_SDK_android9.0.tar     CRC Failed
Sub items Errors: 1
xxx@zzz:/media/build_envs/rockpro64/sdk_android9$ unpigz ROCKPro64_SDK_android9.0.tar.gz
unpigz: abort: corrupted gzip stream -- crc32 mismatch: ROCKPro64_SDK_android9.0.tar.gz
Someone encountering the same behaviour?
  Android images for RockPro64 BitAnnihilator 5 17,851 06-04-2024, 11:05 PM
  Difficulty installing Android on Rockpro64 spammycheese 0 5,697 02-17-2023, 05:31 AM
Last Post: spammycheese
  Using Android and the Playstore grobbs 0 6,039 06-04-2022, 12:18 AM
Last Post: grobbs
  Slash TV Android for RockPro64 Wizzard 12 24,509 04-24-2022, 08:13 AM
Last Post: Rocklobster
  DRM support in Android Wizzard 2 7,470 02-03-2022, 09:16 PM
Last Post: Johnmo89
  Install Playstore on Android 8.1.0 Domo 14 45,524 04-16-2021, 02:13 AM
Last Post: Wizzard
  Install Playstore on Android 7.1.2 Domo 6 25,086 04-16-2021, 02:10 AM
Last Post: Wizzard
  Kodi crashing in Android 9 Wizzard 2 7,584 04-16-2021, 02:03 AM
Last Post: Wizzard
  Install Playstore on Android 9 image ddimension 18 49,416 02-13-2021, 12:52 AM
Last Post: chisteven
  RockPro64 line out/headphones in Android 9 Wizzard 0 6,054 11-20-2020, 04:15 AM
Last Post: Wizzard
