Boot splash on ayufan's Ubuntu
Did anyone get a bootsplash working on ayufan's builds instead of the text on the screen? If so, how did you do it?
To activate bootsplash install plymouth if not already installed, grab some theme from https://www.gnome-look.org/browse/cat/108/
To keep the splashscreen from getting disabled on kernel update, open up /usr/local/sbin/update-extlinux.sh in your editor of choice and change line 50:
emit_kernel "$VERSION" "$APPEND"
to:
emit_kernel "$VERSION" "$APPEND quiet loglevel=3 splash"
then save and run "sudo update-extlinux.sh"
It's possible update-extlinux.sh is updated sometime in the future, but shouldn't be a problem to reapply the changes if it were to happen.
  Boot Order in Pinebook Pro food 12 16,365 05-25-2026, 08:28 AM
Last Post: finmark
  Pinebook pro won't boot after bootloader installation jwensouls 4 7,820 08-21-2024, 04:17 AM
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 10,801 12-11-2023, 03:47 AM
Last Post: calinb
  [Manjaro] u-boot won't boot from eMMC with (unbootable) SD card present zackw 1 6,060 08-21-2023, 09:08 PM
Last Post: vanessadonald
  Emergency Mode Boot Hotkey? jiacovelli 20 18,950 06-02-2023, 01:32 PM
  Tow Boot install help Paulie420 7 10,611 11-24-2022, 10:24 AM
Last Post: myself600
  Resume from suspend not working after flashing Tow-Boot to SPI xp19375 3 5,629 10-31-2022, 10:14 AM
  Bootloader: SD card boot quirks crazyquark 1 3,067 10-04-2022, 12:27 PM
Last Post: elitegamercody
  Fresh Manjaro does not boot from eMMC pentamassiv 7 10,904 08-18-2022, 11:47 AM
Last Post: Bemo
  PBP won’t boot from eMMC after Debian update / Tow-Boot installer won’t boot from SD Pino64 21 26,321 05-12-2022, 05:00 AM
Last Post: Pino64
