Netflix with hardware acceleration not working
Good day Gentlemen & Gentlewomen,
I can't get the Chromium to work with the hardware accelartion.
Usually I wouldn't bother but its impossible to play videos from netflix like that (at least not in fullscreen mode).
Chromium gives me a error like this:
  • [12710:12710:1213/204638.585707:ERROR:gl_surface_egl.cc(1043)] : EGL display query failed with error EGL_SUCCESS
  • [12710:12710:1213/204638.585948:ERROR:gl_surface_egl.cc(1057)] : eglInitialize Default failed with error EGL_BAD_DISPLAY
  • [12710:12710:1213/204638.586005:ERROR:gl_initializer_x11.cc(156)] : GLSurfaceEGL::InitializeOneOff failed.
  • GpuProcessHost: The GPU process exited with code 1024.
I installed the latest libmali - wateland. I also tried some others, getting the same error.
Any hints / ideas ?
Thx in advance.
Problem solved.
Seems like I messed it up while playing with mali-libs... unfortunately I couldnt figure out which libs I screwed up, so at the end I decided to install a fresh image ....
  HBA Card working on Aufan's builds but not in debian, armbian or dietpi charsi 1 4,690 10-29-2021, 11:15 AM
Last Post: TRS-80
  WORKING: GPU-accelerated Widevine Chromium for Ubuntu 64 twilite 0 4,067 09-13-2021, 11:02 AM
Last Post: twilite
  WiFi not working with PCIe SSD installed mikeD 0 2,990 05-25-2021, 07:48 AM
Last Post: mikeD
  Hardware Accelerated Video Playback Guide xkaiser 2 10,304 04-10-2020, 11:52 AM
Last Post: dmitrymyadzelets
  Does anyone have kodi working? blahblahblah 6 12,909 07-19-2019, 08:09 AM
Last Post: PackElend
Information [archived] 0.8.X images from ayufan; Mate DE + video / 3d acceleration Luke 28 58,794 05-18-2019, 02:03 PM
Last Post: rickard
  Grabbing screenshot while hardware decoding StefanRvO 0 3,026 05-16-2019, 09:01 AM
Last Post: StefanRvO
  hardware pwm pins Mentaluproar 1 4,990 02-24-2019, 02:09 AM
  GPU acceleration for compositor Mentaluproar 1 6,605 01-29-2019, 05:18 PM
Last Post: Mentaluproar
  Tutorial: OpenCL 1.2 FULL_PROFILE Working( moved for Tutorials Section ) tuxd3v 0 2,723 11-06-2018, 12:46 PM
Last Post: tuxd3v
