Help me understand the boot up process
I'm obviously missing something fundamental here.
I built an image with buildroot which creates a u-boot-tpl-spl.img, a u-boot.itb file and a root partition
        image = "u-boot-tpl-spl.img"         offset = 32768 # 512 * 0x40 from start of sd card         image = "u-boot.itb"         offset = 262144 # 512 * 0x200 from start of sd card         bootable = "yes"         image = "rootfs.ext2"
In the rootfs partition there's a file called /boot/extlinux.conf which has the following
label rock64-buildroot   kernel /boot/Image   devicetree /boot/rk3328-rock64.dtb   append console=ttyS2,1500000n8 root=/dev/mmcblk0p1 ro rootwait
This boots up and all is good.  However, I'm wondering why I can't just replace /boot/Image and /boot/rk3328-rock64.dtb (and /lib/modules/*) with the one from slack (for example) and have that boot up.
When I tried, it didn't find /boot/Image and tried to boot off the network.
What am I missing here?
  PXE Boot example? lewis 7 18,660 10-08-2025, 06:51 AM
Last Post: LewisHenderson
  How to boot an older, working kernel bits 0 3,190 11-01-2024, 04:43 PM
Last Post: bits
  problem with debian emmc boot G4zCDzWb 10 31,196 11-01-2024, 04:32 PM
Last Post: bits
  arch rock64 does not boot nemnob 1 5,192 09-20-2024, 11:18 AM
Last Post: AwU2HBg
  Rock64 won't boot dstallmo 0 3,504 12-27-2023, 10:34 AM
Last Post: dstallmo
  Disabling last mount time check on boot acwest 0 2,406 03-03-2023, 09:24 PM
Last Post: acwest
  Rock64 Rev3 doesn't boot and leds blinking fast dishins 6 14,265 06-30-2022, 06:28 PM
Last Post: rookie_267
  my rock64 can't boot rookie_267 0 2,963 06-27-2022, 06:52 PM
  Setting a MAC on Rock64 U-Boot kiriakos 2 6,930 03-23-2021, 04:51 AM
Last Post: kiriakos
  Boot from USB 3.0 with hub Turbo 0 3,862 12-20-2020, 02:24 PM
Last Post: Turbo
