Pine A64 +OS X
Does anyone here (not associated with Pine A64) think there would be a way to run OS X on Pine A64 via a microSD?
I plan to use it to analyze data (using R).
I want that to happen. I do have several OS X Disk at home ?
RI
(12-10-2015, 09:27 PM)Eddy120876 Wrote: I want that to happen. I do have several OS X Disk at home ?
Do you think it can be done?
(12-10-2015, 09:34 PM)sh2 Wrote: RI
Of course not. OS X runs on x86. You'll have to meet the hardware specs exactly to be able to let it run on non-Apple hardware.
The A64 is a rather slow ARMv8 implementation (applies to both CPU and GPU). Not even recent iOS versions would run fluently on it.
tkaiser
Sounds great. Thank you.
I don't think OSX will run on Pine A64 board, OSX is Intel based OS that several persons already pointed out and Apple eco-systems always close.
Very well.
At one point I thought about emulation.
(12-10-2015, 11:57 PM)sh2 Wrote: At one point I thought about emulation.
Forget it. While Exagear might be able to emulate older x86 OS/applications that's simply impossible with OS X (at least 10.9 or above) since OS X uses OpenCL running on the GPU extensively. This is an area where CPU emulation fails and again: The A64 is way too slow and the Mali400 GPU not even OpenCL compliant.
At the moment the Pine64 is an Android toy only.
(12-11-2015, 12:08 AM)tkaiser Wrote: At the moment the Pine64 is an Android toy only.
To be honest this will likely be more powerful than a Pi2 so there can be a lot more to it than a simple Android toy. I plan on trying a sripped down ARM version of Debian when I get mine.
I've already made an Ubuntu image for the Pine64: http://forum.armbian.com/index.php/topic...#entry3173
It's quite easy to combine any ARMv7/ARMv8 rootfs with the Android boot.img you now get when using the A64 SDK. But that's not that important since the magic happens somewhere else. It's hardware initialisation and drivers. And I really doubt that we're able to use HW accelerated video encoding/decoding (called CedarX) in Linux and are able to use 2D/3D acceleration (Mali400MP2) there that soon.
BTW: There exist a few more SBC than just the RPi 2 -- many of them way more powerful than the Pine64. What makes a real difference regarding RPi compared to other SBCs is the state of the software. You can even take a RPi A or B from 2012, clock the single CPU core down to 200 MHz and are still able to watch h.264 encoded video or encode a 1080p/h.264 camera stream with 30fps in real-time. Since there drivers are accessible from within Linux that delegate all this stuff to the VideoCore 4 VPU and frees up the ARM core.
Something that's only possible in Android with the A64 at the moment.
  Pine 64 installer OS list blank spamsucks 1 11,492 04-08-2025, 08:16 AM
  PINE A64 SBC: Clone of a functional 32GB SD card doesn't boot burningkrome 3 4,644 05-19-2023, 07:43 AM
Last Post: crocspot
  PINE A64 Ubuntu 18 or 20 IMG with touchscreen? burningkrome 0 2,390 04-29-2023, 05:13 AM
Last Post: burningkrome
  Pine A64 does only boot with Android 5.1 Dude 6 7,801 07-03-2022, 02:18 PM
Last Post: Dude
  Pine A64+ vs LCD do not boot DDS 3 9,209 02-23-2021, 05:33 PM
Last Post: thedu
  Autodetect if Pine unit is a Pine A64+ or PineA64-LTS pkfpeters 1 5,560 02-09-2021, 12:17 AM
  Pine 64 | 2GB x2 & Acrylic Cases x2 for Sale | Canada - GTA ViperVi 1 6,730 01-18-2021, 03:45 PM
Last Post: squidius
  sd format?for pine 64 angegardien 3 11,202 12-06-2020, 03:53 PM
Last Post: junkyj753
  Node Red on the Pine DonFL 0 4,169 12-16-2019, 04:21 PM
Last Post: DonFL
Photo Pine A64+ from Kick starter running Pi-Hole netHolio 0 4,409 12-02-2019, 09:36 PM
Last Post: netHolio
