PCIe
The Pinebook Pro supports PCIe, doesn't it. Lspci shows nothing. I would have expected a root-port or so.
Dmesg:
root@pinebook-pro:~# dmesg | grep pci [    0.679716] ehci-pci: EHCI PCI platform driver [    3.640027] phy phy-pcie-phy.9: Looking up phy-supply from device tree [    3.640043] phy phy-pcie-phy.9: Looking up phy-supply property in node /pcie-phy failed [    3.642592] rockchip-pcie f8000000.pcie: GPIO lookup for consumer ep [    3.642602] rockchip-pcie f8000000.pcie: using device tree for GPIO lookup [    3.642776] of_get_named_gpiod_flags: parsed 'ep-gpios' property of node '/pcie@f8000000[0]' - status (0) [    3.642993] rockchip-pcie f8000000.pcie: Looking up vpcie12v-supply from device tree [    3.643001] rockchip-pcie f8000000.pcie: Looking up vpcie12v-supply property in node /pcie@f8000000 failed [    3.643030] rockchip-pcie f8000000.pcie: no vpcie12v regulator found [    3.643034] rockchip-pcie f8000000.pcie: Looking up vpcie3v3-supply from device tree [    3.643039] rockchip-pcie f8000000.pcie: Looking up vpcie3v3-supply property in node /pcie@f8000000 failed [    3.643050] rockchip-pcie f8000000.pcie: no vpcie3v3 regulator found [    3.643054] rockchip-pcie f8000000.pcie: Looking up vpcie1v8-supply from device tree [    3.643058] rockchip-pcie f8000000.pcie: Looking up vpcie1v8-supply property in node /pcie@f8000000 failed [    3.643069] rockchip-pcie f8000000.pcie: no vpcie1v8 regulator found [    3.643072] rockchip-pcie f8000000.pcie: Looking up vpcie0v9-supply from device tree [    3.643077] rockchip-pcie f8000000.pcie: Looking up vpcie0v9-supply property in node /pcie@f8000000 failed [    3.643087] rockchip-pcie f8000000.pcie: no vpcie0v9 regulator found [    3.643092] rockchip-pcie f8000000.pcie: missing optional "memory-region" property [    3.643097] rockchip-pcie f8000000.pcie: missing optional "rockchip,dma_trx_enabled" property [    3.643101] rockchip-pcie f8000000.pcie: missing optional "rockchip,deferred" property [    3.643112] rockchip-pcie f8000000.pcie: calling really probe [    3.643116] rockchip-pcie f8000000.pcie: PCIe asserting reset [    3.643140] rockchip-pcie f8000000.pcie: advertising gen2/1 training [    3.663596] rockchip-pcie f8000000.pcie: PCIe reset released [    4.163651] rockchip-pcie f8000000.pcie: PCIe link training gen1 timed out. [    4.163667] rockchip-pcie f8000000.pcie: init port failed [    4.163687] rockchip-pcie f8000000.pcie: probe init failed [    4.163710] rockchip-pcie f8000000.pcie: PCIe probe failed. [    4.163812] rockchip-pcie: probe of f8000000.pcie failed with error -110
Are above errors expected? Do you also get them?
It's possible that the Pinebook Pro NVME uses a custom PCIe driver for RockChip CPUs.
A better comparison would be to check the ROCKPro64 which uses the same CPU chip, and has more general purpose PCIe slot. They support SATA cards in addition to a PCIe to NVME card.
But, I would think "lspci" should show something valid.
Arwen Evenstar
Princess of Rivendale
Same problem here. Nothing in lspci and lsblk. Tried to do it in the default Debian and the newer Ubuntu. Modprobe shows that nvme module is loaded. I thought I somehow damaged the cable or something else during the installation, but, since there is another person having the same issue, I would want to know if it's software to blame.
  PCIe 4X socket for optional NVMe adapter -retaing clip broken . ndp 9 19,036 12-19-2019, 05:15 AM
Last Post: ndp
  PCIe card success ? DrYak 0 3,292 11-12-2019, 01:16 PM
Last Post: DrYak
  Rockchip RK3399 PCIe lanes only 2.5GTb/s? Arwen 2 10,079 08-25-2019, 05:51 AM
Last Post: Arwen
