Default OS update log
#61
.... and there will be a Debian 10 in time.
#62
regarding the swapfile issue...
I'm actually surprised that there's a hard-coded file in /etc/fstab.
Debian makes this really easy with the 'dphys-swapfile' package, and it will try to "do the right thing" for your system.
No manual futzing around at all.
#63
(11-04-2019, 07:28 AM)zaius Wrote:
(11-03-2019, 09:16 PM)Der Geist der Maschine Wrote: How to become root is a matter of preference.
This build also includes a root terminal.  I found that some commands worked with it, that did not work with sudo.
Can you provide examples?
#64
Even after the MrFixIt 1.4 update, my Firefox still crashes Every time after 30 seconds. Is that normal ? Is there any patch or workaround known for this issue ?
#65
My Firefox was crashy initially, but since applying all updates, it only crashes when changing or turning on/off a VPN.
#66
If I recall, I was trying to change to directory only root could read.
#67
If I understand correctly what you mean it's not supposed to work, but without exact command and corresponding output/error I can only guess.
#68
(11-05-2019, 09:06 AM)Watercourse Wrote: My Firefox was crashy initially, but since applying all updates, it only crashes when changing or turning on/off a VPN.
Yup... or with any network interface change, like WiFi disconnecting.
#69
Strange, my PBP ran Firefox fine before and after the updates, the Chromium browser never finished 'Loading' when I tried it.
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
your favorite OS Team
#70
( I have the original Mate/Debian still installed)
 I did have to futz with the sound software a little bit to get it going.
   But more recently  I have noticed some of the ads on YouTube do not have sound  ?  (Not that it is a huge deal...But )
   All the videos seem to have sound and some of the ads do  ?
*  I am wondering if that could have anything to do with the fact that this version of FireFox does not appear to have DRM  ?     Thoughts  ?
      LINUX = CHOICES
         **BCnAZ**
               Idea
   Donate to $upport
  Locked out after update Shylocked 5 5,794 09-13-2024, 07:40 AM
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 11,751 12-15-2023, 02:11 PM
  After update, multiple problems, pinebook pro. jd50i 1 4,306 09-16-2023, 09:41 AM
Last Post: jd50i
  Metis package can't update Mangustis 1 4,155 02-22-2023, 03:23 PM
Last Post: robocone
  Keyboard/Touchpad update SH61F83 IC zaphod80013 4 9,802 09-14-2022, 03:56 AM
Last Post: Carl
Big Grin EASY SOLUTION for Manjaro "Missing Keys" Update and Install Failure Zoroaster-Z 0 5,498 08-14-2022, 09:01 PM
Last Post: Zoroaster-Z
  Ring around screen following update tylerjohnson3208 2 5,770 05-10-2022, 01:52 AM
Last Post: diyagabriel
  Wont charge when powered off, and update question pineymousepad 7 14,316 12-11-2021, 09:50 PM
Last Post: pineymousepad
  Issues with External Display After Recent Update reundo 0 3,613 11-18-2021, 06:37 PM
Last Post: reundo
Bug Wrong FN keys after keyboard FW update j4n3z 2 6,082 10-19-2021, 01:57 AM
Last Post: j4n3z
