RP64 Mounting hole dimensions
Hello, I have been trying to find the exact dimensions of the mounting holes for the RP64 since I got it. I have been looking in the wiki and I can't seem to find the dimensions.
There are nice schematics on the wiki with lots of information, however I can't find dimensions anywhere. I have tried to measure the distance between the holes and the holes themselves, but I don't have the tools to get them right.
I would be grateful if someone has them or could point me to them. It should be easy to find since someone has designed the board, I would like to think.
Thanks in advance.
I've had my own case built and used 118.292 x 70.735 mm as the centre to centre dimensions.
(09-07-2019, 10:48 AM)patstew Wrote: I've had my own case built and used 118.292 x 70.735 mm as the centre to centre dimensions.
Thank you, I guess I will have to try your dimensions!
Photo Max Resolution Supported by RP64? hoarfrosty 3 6,425 10-24-2023, 09:58 AM
  Flashed SPI, able to ping RP64 but not boot from sdcard/usb korefuji 2 5,761 08-26-2021, 11:41 AM
Last Post: LMM
  control RP64 power on LMM 0 3,445 04-15-2021, 02:59 AM
Last Post: LMM
Photo DIMENSIONS SCHEME SITEA 3 9,146 03-28-2021, 04:59 AM
Last Post: PsySc0rpi0n
  OpenGL/ES on RP64 Wizzard 3 8,956 09-16-2020, 03:17 PM
Last Post: Wizzard
  Rp64 my new gaming station? NightCrawler504 1 5,247 03-25-2019, 10:48 PM
