ROCK64 not booting
Hi, I'm trying to boot Armbian on a ROCK64 4GB but I'm stuck.
I flashed "Armbian_5.90_Rock64_Debian_stretch_default_4.4.182_desktop.img" on a MicroSD card with Etcher.
From the serial output I get this
DDR version 1.13 20180428
In
LPDDR3
786MHz
Bus Width=32 Col=11 Bank=8 Row=15/15 CS=2 Die Bus-Width=32 Size=4096MB
ddrconfig:7
OUT
U-Boot SPL 2017.09-rockchip-ayufan-1065-g95f6152134 (Aug 26 2019 - 12:40:32)
board_init_sdmmc_pwr_en
setup_ddr_param  1
booted from SPI flash
Trying to boot from SPI
NOTICE:  BL31: v1.3(debug):9d3f591
NOTICE:  BL31: Built : 14:39:02, Jan 17 2018
NOTICE:  BL31:Rockchip release version: v1.3
INFO:    ARM GICv2 driver initialized
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 1
INFO:    plat_rockchip_pmu_init: pd status 0xe
INFO:    BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE initialization. SMC`s destined for OPTEE will return SMC_UNK
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
U-Boot 2017.09-rockchip-ayufan-1065-g95f6152134 (Aug 26 2019 - 12:41:04 +0000)
Model: Pine64 Rock64
DRAM:  4 GiB
MMC:   rksdmmc@ff520000: 0, rksdmmc@ff500000: 1
SF: Detected gd25q128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB
*** Warning - bad CRC, using default environment
In:    serial@ff130000
Out:   serial@ff130000
Err:   serial@ff130000
misc_init_r
cpuid=55524b503039303231000000000f222c
serial=556d7db57902d0a
Net:   eth0: ethernet@ff540000
Hit any key to stop autoboot:  0
Card did not respond to voltage select!
mmc_init: -95, time 9
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1...
Found U-Boot script /boot/boot.scr
2949 bytes read in 21 ms (136.7 KiB/s)
## Executing script at 00500000
Boot script loaded from mmc 1
102 bytes read in 18 ms (4.9 KiB/s)
4460994 bytes read in 234 ms (18.2 MiB/s)
19044360 bytes read in 897 ms (20.2 MiB/s)
73888 bytes read in 126 ms (572.3 KiB/s)
** File not found /boot/dtb/rockchip/overlay/rockchip-fixup.scr **
## Loading init Ramdisk from Legacy Image at 04000000 ...
  Image Name:   uInitrd
  Image Type:   AArch64 Linux RAMDisk Image (gzip compressed)
  Data Size:    4460930 Bytes = 4.3 MiB
  Load Address: 00000000
  Entry Point:  00000000
  Verifying Checksum ... OK
## Flattened Device Tree blob at 01f00000
  Booting using the fdt blob at 0x1f00000
  Loading Ramdisk to fcac0000, end fcf01182 ... OK
  reserving fdt memory region: addr=1f00000 size=78000
  Loading Device Tree to 00000000fca45000, end 00000000fcabffff ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.182-rockchip64 (root@nightly) (gcc version 7.4.1 20181213 [linaro-7.4-2019.02 revision 56ec6f6b99cc167ff0c2f8e1a2eed33b1edc85d4] (Linaro GCC 7.4-2019.02) ) #1 SMP Fri Jun 28 17:34:00 CEST 2019
[    0.000000] Boot CPU: AArch64 Processor [410fd034]
[    0.000000] earlycon: Early serial console at MMIO32 0xff130000 (options '')
[    0.000000] bootconsole [uart0] enabled
ERROR:   suspend_mode_handler: unhandled sip (0x1)
ERROR:   suspend_mode_handler: unhandled sip (0x4)
[   44.727910] reboot: Restarting system
INFO:    PSCI Power Domain Map:
INFO:      Domain Node : Level 2, parent_node -1, State ON (0x0)
INFO:      Domain Node : Level 1, parent_node 0, State ON (0x0)
INFO:      Domain Node : Level 0, parent_node 0, State ON (0x0)
INFO:      CPU Node : MPID 0x0, parent_node 1, State ON (0x0)
INFO:      CPU Node : MPID 0x1, parent_node 1, State ON (0x0)
INFO:      CPU Node : MPID 0x2, parent_node 1, State ON (0x0)
INFO:      CPU Node : MPID 0x3, parent_node 1, State ON (0x0)
while on the screen I get this
[Image: 3FRQEGi.jpg]
and then it reboots and does all this all over again and again...
Could someone help me?
Thanks in advance
I don't have a rock64. From the screen output, I gain the impression that there is an initrd booted off /boot. It does not find an root partition. Can you attach micro SD card to another linux computer and check the sanity of SD card, e.g.
check the partition table via
fdisk /dev/XXX
then mount all partitions.
Does that all work?
A bad image or SD card looks like your problem. Download the image again and write the image to a different SD card to rule both out.
(09-06-2019, 05:45 PM)Der Geist der Maschine Wrote: I don't have a rock64. From the screen output, I gain the impression that there is an initrd booted off /boot. It does not find an root partition. Can you attach micro SD card to another linux computer and check the sanity of SD card, e.g.
fdisk /dev/XXX
Does that all work?
It all seems normal to me
[Image: C0A5zHf.png]
(09-06-2019, 05:59 PM)Rocklobster Wrote: A bad image or SD card looks like your problem. Download the image again and write the image to a different SD card to rule both out.
I downloaded again the Armbain Stretch image, checked the SHA256 and changed MicroSD card from a known good SanDisk Ultra 16GB to a known good Samsung EVO 16GB.
I also tried writing the image with Win32DiskImager but the behavior I get it's still the same as before.
With an old image like "stretch-minimal-rock64-0.6.37-221-arm64.img" I can get it to boot a bit further, but the ending is the same.
Boot log here (too long to fit in this reply)
Uhh. I have no idea what goes wrong in mounting the root filesystem. A desperate attempt would be replacing in boot/armbianEnv.txt
rootdev=UUID=XXX
with
rootdev=/dev/mmcblk0p1
or
rootdev=/dev/sda1
(09-07-2019, 01:37 PM)Der Geist der Maschine Wrote: Uhh. I have no idea what goes wrong in mounting the root filesystem. A desperate attempt would be replacing in boot/armbianEnv.txt
rootdev=UUID=XXX
with
or
rootdev=/dev/sda1
I'm still using "stretch-minimal-rock64-0.6.37-221-arm64.img".
The content of boot/extlinux.conf (edited with /dev/sda1) is the following
timeout 30
default kernel-latest
menu title select kernel
label kernel-latest
   kernel /Image
   initrd /initrd.img
   fdt /dtb
   append rw root=/dev/sda1 rootwait rootfstype=ext4 panic=10 init=/sbin/init coherent_pool=1M ethaddr=${ethaddr} eth1addr=${eth1addr} serial=${serial#} cgroup_enable=cpuset cgroup_memory=1 cgroup_enable=memory swapaccount=1
label kernel-previous
   kernel /Image.bak
   initrd /initrd.img.bak
   fdt /dtb.bak
On the screen i get only the messages with the timestamp at the beginning of the line.
Boot log with /dev/mmcblk0p1 here
Boot log with /dev/sda1 here
Installed latest u-boot and booted no problem from USB with "Armbian_5.90_Rock64_Debian_stretch_default_4.4.182_desktop".
Boot log here
Why doesn't it boot from MicroSD?!  Angry
I noticed that all 3 LEDs that are present on the board (DC in, PWR, STBY) stay lit all the time, is it normal?
Maybe someone else can help you, but I think you are doomed to help yourself. Perhaps rebuild initrd and include busybox. Then boot into the busybox shell and look around.
Read this Wiki carefully. The presence of uboot may be your problem https://wiki.pine64.org/index.php/NOOB
All LEDs remain lit on the board.
(09-08-2019, 01:42 PM)Rocklobster Wrote: Read this Wiki carefully. The  presence of uboot may be your problem https://wiki.pine64.org/index.php/NOOB
Trying to boot "Armbian_5.90_Rock64_Debian_stretch_default_4.4.182_desktop" from MircoSD.
Boot log with u-boot here and without u-boot here.
As you can see I'm not able to boot in either case and on the screen I get the same things as in the photo in the first post.
While flashing/erasing the SPI flash with the tools provided here I should see the LEDs blinking but instead I get error messages regarding setting the LEDs status and all the LEDs stay lit. Is this a bug of the software or is it a problem with my board?
Erasing log here and flashing log here.
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 5,495 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 26,364 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 15,617 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 17,234 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 4,272 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 9,114 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 10,191 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 9,433 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 4,464 11-28-2022, 02:18 PM
Last Post: Macgyver
  my rock64 dosen't work rookie_267 0 4,569 10-07-2022, 07:50 PM
Last Post: rookie_267
