u-boot for Arch Linux Arm
Hi all,
I've put together a PKGBUILD for building u-boot for the rockpro64.
I have some instructions and the uboot binary and boot.scr here:
https://github.com/prw/PKGBUILDs/release...ot_testing
The mainline linux-aarch64 kernel is functional but is definitely not optimal for this board.
The kernel is quite slow to boot and takes 3-5 minutes.
U-boot is based on ayufan's linux-u-boot.
I hope someone finds this useful.
(07-19-2019, 10:00 PM)prw Wrote: Hi all,
Thats great as a big fan of Arch and will be having a look at how you did PKGBUILD.
Manjaro in a way have pipped you to the post though as
https://forum.manjaro.org/t/manjaro-arm-...ased/91858
The minimal version has sort of already been done for us
https://osdn.net/projects/manjaro-arm/st...mal/19.06/
Ahhh, I did not know about the manjaro port when I started working on this. Thanks for pointing this out.
Unfortunately I believe they have built their uboot incorrectly.
The board can easily be crashed by reading 3-4GB of data.
I can crash the manjaro image by running: dd if=/dev/mmcblk0 of=/dev/null bs=1M
It crashes after reading ~3.4GB.
uboot is not correctly initializing the memory controller properly and the kernel crashes once enough cache is used.
(07-20-2019, 10:18 AM)prw Wrote: Ahhh, I did not know about the manjaro port when I started working on this. Thanks for pointing this out.
Uboot is pure mainline as far as I know
Go tell the devs as they will be happy for the info.
  irradium (based on crux linux) RockPro64 riscv64, aarch64 mara 13 22,859 09-27-2026, 11:42 AM
  Boot/Shutdown on timer captainmorgan 8 16,373 11-01-2023, 12:08 PM
Last Post: Nikolay_Po
Exclamation Ethernet regression on Linux Kernel 6.5.4? Deathcrow 3 6,244 09-22-2023, 04:27 AM
Last Post: diederik
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 8,562 07-14-2023, 04:22 AM
Last Post: hunderteins
Question How do I compile an arbitrary kernel for U-Boot? Valenoern 3 7,063 06-16-2023, 10:54 AM
Last Post: CounterPillow
  Linux laptop does not detect the board when plugged in via USB soupy 1 7,958 04-13-2023, 03:01 AM
Last Post: Reynold Grady
  RockPro64 boot questions misterc 3 6,899 01-13-2023, 06:21 PM
Last Post: misterc
  Is some u-boot required on the SPI for installing debian with the official installer? callegar 1 4,176 10-25-2022, 10:07 AM
Last Post: ratzzupaltuff
  RockPro64 linux console video mode callegar 0 2,961 09-06-2022, 02:32 PM
Last Post: callegar
Brick Maintained Linux booting from eMMC ootoovak 10 18,497 04-30-2022, 03:57 PM
Last Post: TRS-80
