DOA Pine64 ?
#21
i currently have a different problem i see the Pine A64 logo and thats it ... lol
Thanks for your ideas...I appreciate it.
It's a shame...hopefully things turn around.
I've sort of run out of options. Right now I think mine may actually be dead.
ok after watiing for about 15 minutes the screen changed to a pulsating RemixOS and now waiting more lol
"congratulations" (?)
btw did you check your micro card ?
http://wiki.pine64.org/index.php/Pine_A6...re_Release
Detecting USB Counterfeit Drives
H2testw 1.4 – Gold Standard In Detecting USB Counterfeit Drives
F3 - an alternative to h2testw
This will help you to determine if the SD-Card is Counterfeit Drive or not.
(04-01-2016, 02:55 PM)mcwebster Wrote: Hi all,
Would like to say it's great to be here, but it's with frustration I make my first post. I've taken delivery of my PA642GB, and tried to set it up, all to no avail, so far I've tried:
1. 4 * 2amp USB Chargers
2. 4 * Micro USB Cables
3. Nothing attached to the Pine except for power, HDMI, and Micro SD card
4. I'm using the sun50iw1p1_android_db1000_uart0_0216.img image, which has burn correctly.
I get a red light by the power socket, but nothing else, not even a boot screen, and have the feeling I may has received a dodgy board.
I have vast experience with Raspberry Pi's so am no newbie to this.
Any advice would be gratefully received.
Many thanks
Mark
Please make sure you are using Phoenixcard software to program the microSD card, and remember to set write mode to "startup".
Thanks for the suggestions guys, I've now tried the RemixOS image as well, still dead, not even a boot image. I've burnt both the Android and the RemixOS using the Phoenixcard software in startup mode. Also should be said, I have tested the card, and it is genuine.
Is it a question of getting in touch with Pine themselves now? I'm all for new tech and brave ventures, but if it doesn't work,then something has to be done!!
Exclamation
Getting beyond frustrated. Pine64 1GB RAM/GigEth (Holiday Pine) - board arrived from China in a padded mailer inside the padded mailer was a cardboard box, branded with Pine64, which was a bit crunched up.
I've been through, like others, multiple micro SD cards, TypeA to Micro USB cables, and so many power supplies it is silly (iPad charger that delivers 2.4A @ 5VDC - I even load tested it!, an Anker 5-port USB charging station that can do 2.4A per port, a supply that works fine with my RaspI 2, it goes on and on, ending at a bench power supply calibrated and dialed into 5VDC and capable of delivering somewhere in the neighborhood of 15A @ 5VDC single-rail.  O-scope shows no notable ripple.).
MicroSD's - I've tried big (32/64GB), small (4/8gb), cheap, expensive (SanDisk, Lexar), every OS image released burned as prescribed in Startup formatting normal first, and none inserted at all.
In every case, all I get is a red power LED (why they chose red, I will never know - these days one expects red to be associated with a fault, or activity).  HDMI 1080p TV, HDMI dell monitor, both known good, short HDMI cables, long HDMI cables, premium HDMI cables... I never even get HDMI sync.
What am I missing?  Otherwise, how can I kick this piece back to PINE and get a replacement or refund?
looks like quite a lot of us are having the same issue. I am on the verge of asking for a refund a perhaps buying a fire tv or a Pi3. I have never struggled so much with writing am image to a card and booting a device and as for this whole power thing.. its an absolute joke!
Hey all,
Check out my thread I just posted, if you are using a display adapter it could be causing it not to display at all
http://forum.pine64.org/showthread.php?tid=542
  Having trouble reading MPU6050 sensor via I²C on Pine64 Jaxon 3 10,443 10-21-2025, 10:13 AM
  Wi-Fi/Bluetooth for PINE64, Model: Sopine A64 lamson 0 3,782 08-24-2021, 08:17 AM
Last Post: lamson
  AC Adapter Which One? Pine64 A64 DB V1.1 2GB REV B (Year 2016) databaseprogrammer 2 7,153 06-17-2021, 05:35 AM
Last Post: kqlnut
  Just discovered Pine64 ! - first Q philip_rhoades 4 10,335 04-29-2020, 10:13 AM
  A newest user in Pine64 Aliko 1 6,654 04-19-2020, 10:33 PM
  PINE64 Installer - Simple Way to Image Your MicroSD pineadmin 101 216,882 01-15-2020, 12:46 PM
  Emails from pine64 received as spam by gmail Matan 2 15,222 08-21-2019, 08:30 AM
Last Post: Leiaz
  How to handle a Pine64 correctly gbjensen 6 23,180 03-28-2019, 11:43 PM
Last Post: InsideJob
Information Creating a NAS server in Pine64 javi_cala 4 12,544 01-21-2019, 02:03 AM
Last Post: bartes
  The 6 most common reasons why Pine64 won't boot Andrew2 109 308,447 10-11-2018, 11:35 PM
Last Post: Technolab88
