Storage in Android
What should I do replace the storage from internal storage to SD card
My android phone can not give me the way, how to replace it
When I download a thing, the notification directly appears that your memory storage is full. Actually, I have plugged in my SD card
So, how to manage, what should I do
Image result for replace the storage from internal storage to SD card android
Open the Settings app, tap the “Storage & USB” option, and you'll see any external storage devices appear here. To turn a “portable” SD card into internal storage, select the device here, tap the menu button in the top-right corner of your screen, and select “Settings.”
The exact steps are too long to tell and you can check it yourself:https://docsbay.net/how-to-set-up-a-new-sd-card-in-android-for-extra-storage
  Android Images (ROCK64) pineadmin 77 247,060 11-18-2024, 08:21 AM
Last Post: reukiodo
Wink Android ( Stock or TV version ) rooted image please !!! AngelfromSpain 5 13,534 05-13-2024, 12:32 PM
  Rock64 Android Oreo 8.1 TV-Install adventures (Now Android 9.0) Rocklobster 5 13,810 08-04-2021, 07:35 PM
Last Post: Rocklobster
  How do I prepare/put Android on an SD card using etcher cdotsubo3000 3 11,979 06-27-2021, 02:43 PM
Last Post: clach04
  Android and SD Card gigagames 2 8,953 06-27-2021, 02:38 PM
Last Post: clach04
  Android 9.0 and Pluto on Rock64-1G missdeenola 1 7,655 03-12-2021, 01:38 PM
Last Post: Wizzard
  broken android microsd images jbach50 1 6,813 01-16-2021, 09:57 PM
Last Post: jimsurvak
  Android on Rock64 SD Problem ElBoluTony 3 11,494 10-07-2020, 12:10 PM
Last Post: ElBoluTony
  Error! Android Rockchip tools method BowerR64 0 5,738 09-18-2020, 08:12 PM
Last Post: BowerR64
Lightbulb Any older versions of Android for the Rock64? BowerR64 2 9,102 09-18-2020, 07:58 PM
Last Post: BowerR64
