Update 22.02.2019 Feature-complete Debian build - SDIO WiFi/BT / PCIe / 3D / 2D
Information
A feature complete Debian build from mrfixit2001 is now available.
Download Link
More Info:
[edit 22.02.2019]  Update to Debian from mrfixit2001
Quote:
  • Kernel updated to 4.4.171
  • Additional mainline back-ports and custom fixes
  • Additional drivers added to kernel
  • PCIe now works with Wifi and Bluetooth all at the same time
  • UART debug output enabled
I'll add from myself that a Mali blob better suited to desktop usage scenarios has been added.
[edit] log in credentials: rock/rock
Quote:File System Updates:
  • Added a feature to the boot script that lets the user change the default to use only 2 partitions instead of creating the third (see the readme for details)
  • Included additional firmware and modules
  • Corrected alsa sound file
Kernel Updates:
  • Updated to version 4.4.169
  • Various custom kernel fixes, mainline backports, stability and other enhancements
  • Fix for 4K Playback @ 60fps - smooth playback and Audio/Video are synced
Rockpro Specific Updates:
Nice,but on my rp64 v2.1 2GB i don't have pcie.
pastebin
root@localhost:/home/rock# lspci -nn
root@localhost:/home/rock# lspci -vvv
Edit:
Uuupps, after reboot i got this.
00:00.0 PCI bridge: Device 1d87:0100 (prog-if 00 [Normal decode])
    Control: I/O- Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
    Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort+ <TAbort+ <MAbort+ >SERR+ <PERR+ INTx-
    Latency: 0
    Interrupt: pin A routed to IRQ 244
    Bus: primary=00, secondary=01, subordinate=01, sec-latency=0
    I/O behind bridge: 00000000-00000fff
    Memory behind bridge: fa000000-fa0fffff
    Prefetchable memory behind bridge: 00000000-000fffff
    Secondary status: 66MHz- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- <SERR- <PERR-
    BridgeCtl: Parity- SERR- NoISA- VGA- MAbort- >Reset- FastB2B-
        PriDiscTmr- SecDiscTmr- DiscTmrStat- DiscTmrSERREn-
    Capabilities: [80] Power Management version 3
        Flags: PMEClk- DSI- D1+ D2- AuxCurrent=0mA PME(D0+,D1+,D2-,D3hot+,D3cold-)
        Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME+
    Capabilities: [90] MSI: Enable+ Count=1/1 Maskable+ 64bit+
        Address: 00000000fee30040  Data: 0000
        Masking: 00000000  Pending: 00000000
    Capabilities: [b0] MSI-X: Enable- Count=1 Masked-
        Vector table: BAR=0 offset=00000000
        PBA: BAR=0 offset=00000008
    Capabilities: [c0] Express (v2) Root Port (Slot+), MSI 00
        DevCap:    MaxPayload 256 bytes, PhantFunc 0
            ExtTag- RBE+
        DevCtl:    Report errors: Correctable+ Non-Fatal+ Fatal+ Unsupported+
            RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+
            MaxPayload 128 bytes, MaxReadReq 512 bytes
        DevSta:    CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr- TransPend-
        LnkCap:    Port #0, Speed 5GT/s, Width x4, ASPM L1, Exit Latency L0s <256ns, L1 <8us
            ClockPM- Surprise- LLActRep- BwNot+ ASPMOptComp+
        LnkCtl:    ASPM L1 Enabled; RCB 64 bytes Disabled- CommClk-
            ExtSynch- ClockPM- AutWidDis- BWInt+ AutBWInt+
        LnkSta:    Speed 5GT/s, Width x4, TrErr- Train- SlotClk- DLActive- BWMgmt- ABWMgmt-
        SltCap:    AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug- Surprise-
            Slot #0, PowerLimit 0.000W; Interlock- NoCompl-
        SltCtl:    Enable: AttnBtn- PwrFlt- MRL- PresDet- CmdCplt- HPIrq- LinkChg-
            Control: AttnInd Off, PwrInd Off, Power+ Interlock-
        SltSta:    Status: AttnBtn- PowerFlt- MRL+ CmdCplt- PresDet- Interlock-
            Changed: MRL- PresDet- LinkState-
        RootCtl: ErrCorrectable- ErrNon-Fatal- ErrFatal- PMEIntEna+ CRSVisible-
        RootCap: CRSVisible-
        RootSta: PME ReqID 0000, PMEStatus- PMEPending-
        DevCap2: Completion Timeout: Range B, TimeoutDis+, LTR+, OBFF Via message ARIFwd+
        DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis-, LTR-, OBFF Disabled ARIFwd-
        LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
             Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
             Compliance De-emphasis: -6dB
        LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete-, EqualizationPhase1-
             EqualizationPhase2-, EqualizationPhase3-, LinkEqualizationRequest-
    Capabilities: [100 v2] Advanced Error Reporting
        UESta:    DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
        UEMsk:    DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
        UESvrt:    DLP+ SDES+ TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
        CESta:    RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr-
        CEMsk:    RxErr- BadTLP- BadDLLP- Rollover- Timeout- NonFatalErr+
        AERCap:    First Error Pointer: 00, GenCap+ CGenEn- ChkCap+ ChkEn-
    Capabilities: [274 v1] Transaction Processing Hints
        Interrupt vector mode supported
        Device specific mode supported
        Steering table in TPH capability structure
    Kernel driver in use: pcieport
01:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd Device a804 (prog-if 02 [NVM Express])
    Subsystem: Samsung Electronics Co Ltd Device a801
    Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
    Latency: 0
    Interrupt: pin A routed to IRQ 243
    Region 0: Memory at fa000000 (64-bit, non-prefetchable) [size=16K]
    Capabilities: [40] Power Management version 3
        Flags: PMEClk- DSI- D1- D2- AuxCurrent=0mA PME(D0-,D1-,D2-,D3hot-,D3cold-)
        Status: D0 NoSoftRst+ PME-Enable- DSel=0 DScale=0 PME-
    Capabilities: [50] MSI: Enable- Count=1/32 Maskable- 64bit+
        Address: 0000000000000000  Data: 0000
    Capabilities: [70] Express (v2) Endpoint, MSI 00
        DevCap:    MaxPayload 256 bytes, PhantFunc 0, Latency L0s unlimited, L1 unlimited
            ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 0.000W
        DevCtl:    Report errors: Correctable- Non-Fatal- Fatal- Unsupported-
            RlxdOrd+ ExtTag- PhantFunc- AuxPwr- NoSnoop+ FLReset-
        DevSta:    CorrErr- UncorrErr- FatalErr- UnsuppReq- AuxPwr+ TransPend-
        LnkCap:    Port #0, Speed 8GT/s, Width x4, ASPM L1, Exit Latency L0s unlimited, L1 <64us
            ClockPM+ Surprise- LLActRep- BwNot- ASPMOptComp+
            ExtSynch- ClockPM+ AutWidDis- BWInt- AutBWInt-
        LnkSta:    Speed 5GT/s, Width x4, TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
        DevCap2: Completion Timeout: Range ABCD, TimeoutDis+, LTR+, OBFF Not Supported
        LnkCtl2: Target Link Speed: 8GT/s, EnterCompliance- SpeedDis-
    Capabilities: [b0] MSI-X: Enable+ Count=8 Masked-
        Vector table: BAR=0 offset=00003000
        PBA: BAR=0 offset=00002000
    Capabilities: [148 v1] Device Serial Number 00-00-00-00-00-00-00-00
    Capabilities: [158 v1] Power Budgeting <?>
    Capabilities: [168 v1] #19
    Capabilities: [188 v1] Latency Tolerance Reporting
        Max snoop latency: 0ns
        Max no snoop latency: 0ns
    Capabilities: [190 v1] L1 PM Substates
        L1SubCap: PCI-PM_L1.2+ PCI-PM_L1.1+ ASPM_L1.2+ ASPM_L1.1+ L1_PM_Substates+
              PortCommonModeRestoreTime=10us PortTPowerOnTime=10us
        L1SubCtl1: PCI-PM_L1.2- PCI-PM_L1.1- ASPM_L1.2- ASPM_L1.1-
               T_CommonMode=0us LTR1.2_Threshold=0ns
        L1SubCtl2: T_PwrOn=10us
    Kernel driver in use: nvme
Nice Smile
Now i will test wlan
Quote:root@localhost:/home/rock# iw wlan0 info
Interface wlan0
    ifindex 3
    wdev 0x1
    addr ac:83:f3:e6:1f:b2
    type managed
    wiphy 0
    txpower 31.00 dBm
1. Quartz64 Model B, 4GB RAM
2. Quartz64 Model A, 4GB RAM
3. RockPro64 v2.1
https://linux-nerds.org/
(01-15-2019, 01:30 PM)Bullet64 Wrote: Nice,but on my rp64 v2.1 2GB i don't have pcie.
pastebin
Edit:
    Latency: 0
            ExtTag- RBE+
    Latency: 0
Nice Smile
Interface wlan0
    ifindex 3
    wdev 0x1
    type managed
    wiphy 0
    txpower 31.00 dBm
I think there will be a PCIe update soon for this image.
Yes - Luke is correct! The current release includes some PCIe support but there will be additional functionality and drivers added to an updated release soon, as well as an updated ROCK64 and RockBox release. Thanks for your patience, all!
Guys,
Thanks for this release!
But I am running into some kind off noob problems when testing this image.
I have successfully flashed the image and can log in in the tty environment with root and rock user. I have installed gnome, lightdm and gdm. the gdm device manager is giving me some kind of black screen with a restart.
My question is how do I achieve in this version to start up with a GUI instead of the CLI. I would like to use this version with Kodi regarding the fix for the output of the headphone.
thanks in advance for your reply.
Pepijn.
(01-16-2019, 03:12 PM)Pepijn Wrote: Guys,
Pepijn.
X2, planning on realising a desktop environment img? Armbian looks to be making some nice improvements but for me media is all I'm missing, could care less for pcie, did use your recalbox img and it's very nice just don't get around to play much use more for media, nas, and p2p sharing as well as managing a pi hole and printer sharing, so I'm interested on trying all new images, hoping for the one that finally suits my needs, media atm the only throwback on other builds.
Seeing your work on recall hope you can be the first to get a clean build that does media.
Lukasz actually talked me into doing a desktop image at some point in the future Wink but there's some stuff in the works we have to complete before that. There will be another update to the Debian image coming soon with a few updates, including the ability to update it without reimagining from then on.
For now, you can install a desktop package that uses gbm (sounds like mate runs well) and the kernel will do all the high def media stuff you need Smile
(01-16-2019, 10:02 PM)Mrfixit2001 Wrote: Lukasz actually talked me into doing a desktop image at some point in the future Wink but there's some stuff in the works we have to complete before that. There will be another update to the Debian image coming soon with a few updates, including the ability to update it without reimagining from then on.
nice, guess ill try, if I get it to work as I want will definitely reply, share expirience.
I installed the Mate desktop and everything works. But I have a problem. How to correctly install chromium step by step ??
After installation with the command '' sudo apt install -y chromium ''
Chromium installs but does not start
Thumbs Up
(01-18-2019, 01:52 AM)festor89 Wrote: I installed the Mate desktop and everything works. But I have a problem. How to correctly install chromium step by step ??
Try launching chromium from the terminal, and see what it says. code: chromium-browser
That's how I debug my programs when they break.  Cool
  Freezes and kernel panics with Debian trixie jssfr 4 2,508 04-15-2026, 06:48 PM
Last Post: prahal
  RK3399 PCIe enumeration jhadd 0 2,748 01-31-2024, 08:56 AM
Last Post: jhadd
  Vanilla mainline Debian 11 (Bullseye) on the RockPro64 Pete Tandy 22 39,643 08-16-2023, 01:34 AM
Last Post: varac
  Installing CH431SER on Ayufan 0.9.14: gitlab-ci-linux-build-159 Thisone 4 7,036 07-14-2023, 04:22 AM
Last Post: hunderteins
  How do I enable Pine touchdisplay as display on Debian? Thisone 0 2,677 04-23-2023, 11:02 PM
Last Post: Thisone
  GPIO on Ayufan 0.9.14 Build Thisone 7 8,480 04-23-2023, 01:32 PM
Last Post: diederik
  Is some u-boot required on the SPI for installing debian with the official installer? callegar 1 3,608 10-25-2022, 10:07 AM
Last Post: ratzzupaltuff
  Can RockPRO64 support PCIe Endpoint? andrewg132 3 6,345 10-14-2022, 06:24 AM
Last Post: rwk-
  bullseye 11.3 WiFi drivers moserwi 0 2,782 03-28-2022, 02:01 PM
Last Post: moserwi
  Install Mali 400 Drivers for Debian 11 on RockPro64 MaverickPi 2 5,848 02-19-2022, 06:44 AM
Last Post: sigmaris
Users browsing this thread: 21 Guest(s)
