Not able to write u-boot to SPI
Hello everyone.
I have a trouble flashing uboot to my RockPro64 4GB variant. I am trying to use rock64_write_spi_flash.sh script, but nothing is flashing.
I made all steps according to wiki, booted from SD card, used latest ubuntu image, but everything I get is following error:
rock64@rockpro64:/dev$ sudo su
[sudo] password for rock64:
root@rockpro64:/dev# rock64_write_spi_flash.sh
Doing this will overwrite data stored on SPI Flash
 and it will require that you use eMMC or SD
 as your boot device.
Type YES to continue or Ctrl-C to abort.
YES
Writing /dev/mtd0 with content of /usr/lib/u-boot-rockpro64/rkspi_loader.img
Erasing 4 Kibyte @ 0 --  0 % complete libmtd: error!: MEMERASE64 ioctl failed for eraseblock 0 (mtd0)
       error 110 (Connection timed out)
flash_erase: error!: /dev/mtd0: MTD Erase failure
Erasing 4 Kibyte @ 1000 --  0 % complete libmtd: error!: MEMERASE64 ioctl failed for eraseblock 1 (mtd0)
Erasing 4 Kibyte @ 2000 --  0 % complete libmtd: error!: MEMERASE64 ioctl failed for eraseblock 2 (mtd0)
Erasing 4 Kibyte @ 3000 --  0 % complete libmtd: error!: MEMERASE64 ioctl failed for eraseblock 3 (mtd0)
Erasing 4 Kibyte @ 4000 --  0 % complete libmtd: error!: MEMERASE64 ioctl failed for eraseblock 4 (mtd0)
Erasing 4 Kibyte @ 5000 --  0 % complete ^C^C
I have even tried steps written here: https://forum.pine64.org/showthread.php?...e#pid40677   (,only changed the overlay address to "ff1d0000" to fit to RockPro64 dts).
I never flashed anything to SPI before, so it can't be messed up. I tried the SD card method with only ayufan uboot image and this don't work either. Nothing is written to it..
Output of "mtdinfo":
root@rockpro64:/dev# mtdinfo
Count of MTD devices:           3
Present MTD devices:            mtd0, mtd1, mtd2
Sysfs interface supported:      yes
root@rockpro64:/dev# mtdinfo /dev/mtd0
mtd0
Type:                           nor
Eraseblock size:                4096 bytes, 4.0 KiB
Amount of eraseblocks:          1016 (4161536 bytes, 4.0 MiB)
Minimum input/output unit size: 1 byte
Sub-page size:                  1 byte
Character device major/minor:   90:0
Bad blocks are allowed:         false
Device is writable:             true
root@rockpro64:/dev# mtdinfo /dev/mtd1
mtd1
Type:                           nor
Amount of eraseblocks:          8 (32768 bytes, 32.0 KiB)
Character device major/minor:   90:2
root@rockpro64:/dev# mtdinfo /dev/mtd2
mtd2
Type:                           nor
Amount of eraseblocks:          64 (262144 bytes, 256.0 KiB)
Character device major/minor:   90:4
Output of dmesg:
root@rockpro64:/dev# dmesg | grep spi
[    2.015555] rockchip-spi ff1d0000.spi: Failed to request TX DMA channel
[    2.016160] rockchip-spi ff1d0000.spi: Failed to request RX DMA channel
[    2.016778] rockchip-spi ff1d0000.spi: no high_speed pinctrl state
[    2.017904] m25p80 spi32766.0: gd25q128 (16384 Kbytes)
[    2.018394] 3 ofpart partitions found on MTD device spi32766.0
[    2.018924] Creating 3 MTD partitions on "spi32766.0":
[  164.537097] m25p80 spi32766.0: flash operation timed out
[  204.537255] m25p80 spi32766.0: flash operation timed out
[  244.537347] m25p80 spi32766.0: flash operation timed out
[  284.537402] m25p80 spi32766.0: flash operation timed out
[  324.537509] m25p80 spi32766.0: flash operation timed out
[  364.537587] m25p80 spi32766.0: flash operation timed out
Thanks for any suggestions. This is really driving me nuts.. Any help will be appreciated.. :-)
Hi! I have same issue.I tried all roms from https://github.com/ayufan-rock64/linux-build/releases
I found two solution:
1. https://github.com/ayufan-rock64/linux-u-boot/releases write image and do boot, spi will be writen, white led will blinking.
2. I was able to flash SPI using http://wiki.pine64.org/index.php/ROCKPro...htly_Build , do download files from first link in os
Please use this image to write to spi.
https://github.com/ayufan-rock64/linux-u...o64.img.xz
Quick test
U-Boot SPL 2017.09-rockchip-ayufan-1035-gd646df03ac (Oct 26 2018 - 08:36:09)
booted from SD
Trying to boot from MMC2
NOTICE:  BL31: v1.3(debug):65aa5ce
NOTICE:  BL31: Built : 10:47:37, Jun 19 2018
NOTICE:  BL31: Rockchip release version: v1.1
INFO:    GICv3 with legacy support detected. ARM GICV3 driver initialized in EL3
INFO:    Using opteed sec cpu_context!
INFO:    boot cpu mask: 0
INFO:    plat_rockchip_pmu_init(1151): pd status 3e
INFO:    BL31: Initializing runtime services
WARNING: No OPTEE provided by BL2 boot loader, Booting device without OPTEE iniK
ERROR:   Error initializing runtime service opteed_fast
INFO:    BL31: Preparing for EL3 exit to normal world
INFO:    Entry point address = 0x200000
INFO:    SPSR = 0x3c9
U-Boot 2017.09-rockchip-ayufan-1035-gd646df03ac (Oct 26 2018 - 08:36:24 +0000)
Model: Pine64 RockPro64
DRAM:  2 GiB
DCDC_REG1@vdd_center: ; enabling
DCDC_REG2@vdd_cpu_l: ; enabling
DCDC_REG3@vcc_ddr: ; enabling (ret: -38)
DCDC_REG4@vcc_1v8: set 1800000 uV; enabling
LDO_REG1@vcc1v8_dvp: set 1800000 uV; enabling
LDO_REG2@vcc3v0_touch: set 3000000 uV; enabling
LDO_REG3@vcc1v8_pmu: set 1800000 uV; enabling
LDO_REG4@vcc_sd: set 3300000 uV; enabling
LDO_REG5@vcca3v0_codec: set 3000000 uV; enabling
LDO_REG6@vcc_1v5: set 1500000 uV; enabling
LDO_REG7@vcca1v8_codec: set 1800000 uV; enabling
LDO_REG8@vcc_3v0: set 3000000 uV; enabling
SWITCH_REG1@vcc3v3_s3: ; enabling (ret: -38)
SWITCH_REG2@vcc3v3_s0: ; enabling (ret: -38)
vcc1v8-s0@vcc1v8_s0: set 1800000 uV; enabling (ret: -38)
dc-12v@dc_12v: set 12000000 uV; enabling (ret: -38)
vcc-sys@vcc_sys: set 5000000 uV; enabling (ret: -38)
vcc3v3-sys@vcc3v3_sys: set 3300000 uV; enabling (ret: -38)
vcc-phy-regulator@vcc_phy: ; enabling (ret: -38)
vdd-log@vdd_log: ; enabling (ret: -38)
MMC:   sdhci@fe330000: 0, dwmmc@fe320000: 1
SF: Detected gd25q128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB
*** Warning - bad CRC, using default environment
In:    serial@ff1a0000
Out:   serial@ff1a0000
Err:   serial@ff1a0000
Net:   eth0: ethernet@fe300000
Hit any key to stop autoboot:  0
Card did not respond to voltage select!
mmc_init: -95, time 19
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:2...
Found U-Boot script /boot.scr
reading /boot.scr
827 bytes read in 3 ms (268.6 KiB/s)
## Executing script at 00500000
reading rkspi_loader.img
1461372 bytes read in 156 ms (8.9 MiB/s)
SF: 4194304 bytes @ 0x0 Erased: OK
device 0 offset 0x0, size 0x164c7c
SF: 1461372 bytes @ 0x0 Written: OK
And please use image for rockpro64 Exclamation
1. Quartz64 Model B, 4GB RAM
2. Quartz64 Model A, 4GB RAM
3. RockPro64 v2.1
https://linux-nerds.org/
  (real) Mainline U-boot finally works on SPI, boots SATA, throw away your SD cards NOW aleksei 0 12,071 06-21-2025, 06:21 AM
Last Post: aleksei
  enble boot after power loss/restore dkebler 18 26,061 12-04-2023, 12:14 PM
Last Post: ok38
  Mainline U-Boot with SPI, NVMe and SATA boot support sigmaris 108 205,967 09-25-2023, 12:46 AM
Last Post: ChriChri
Bug Broken boot: What am I missing? mkosarek 1 3,731 09-08-2023, 08:14 AM
  Unable to boot Armbian on new RockPro64 mooseball 5 12,208 07-14-2023, 08:59 AM
Last Post: rockjonn
  no boot white led flashing moserwi 7 12,312 05-18-2023, 10:46 AM
  u-boot locked on pine64pro ljones 1 4,104 09-06-2022, 10:32 AM
Last Post: ljones
  Cannot get my board to boot deutschlmao 11 17,991 09-05-2022, 04:23 PM
Last Post: ljones
  U-BOOT Tutorial hazz 0 3,190 07-19-2022, 10:48 PM
Last Post: hazz
  Installation Debian on emmc: which U-Boot and where? vongillus 3 7,161 07-02-2022, 09:24 AM
Last Post: dkebler
