Tool to Control Fan - fanctl
#21
In an unloaded state,
date, time, cores frequency, temperature, PWM:
2018-09-20,00:06:43,408,408,408,408,816,816,39,0
2018-09-20,00:06:44,408,408,408,408,816,816,40,0
2018-09-20,00:06:45,408,408,408,408,816,816,39,190
2018-09-20,00:06:46,408,408,408,408,816,816,40,190
2018-09-20,00:06:47,408,408,408,408,816,816,40,115
2018-09-20,00:06:48,408,408,408,408,408,408,40,115
2018-09-20,00:06:49,408,408,408,408,816,816,39,115
2018-09-20,00:06:50,408,408,408,408,816,816,39,115
2018-09-20,00:06:51,408,408,408,408,816,816,40,115
2018-09-20,00:06:52,408,408,408,408,816,816,40,0
2018-09-20,00:06:53,408,408,408,408,816,816,40,0
2018-09-20,00:06:54,408,408,408,408,816,816,39,0
2018-09-20,00:06:55,408,408,408,408,816,816,39,0
#!/bin/sh
while true :
do
 now=$(date "+%F,%H:%M:%S")
 temp=$(cat /sys/devices/virtual/thermal/thermal_zone0/temp)
 freq0=$(cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_cur_freq)
 freq1=$(cat /sys/devices/system/cpu/cpu1/cpufreq/scaling_cur_freq)
 freq2=$(cat /sys/devices/system/cpu/cpu2/cpufreq/scaling_cur_freq)
 freq3=$(cat /sys/devices/system/cpu/cpu3/cpufreq/scaling_cur_freq)
 freq4=$(cat /sys/devices/system/cpu/cpu4/cpufreq/scaling_cur_freq)
 freq5=$(cat /sys/devices/system/cpu/cpu5/cpufreq/scaling_cur_freq)
 pwm1=$(cat /sys/class/hwmon/hwmon0/pwm1)
 echo $now,$(( freq0 /1000 )),$(( freq1 /1000 )),$(( freq2 /1000 )),$(( freq3 /1000 )),$(( freq4 /1000 )),$(( freq5 /1000 )),$(( temp / 1000 )),$(( pwm1 )) >> /var/log/temperature.log
 sleep 1
done
(09-15-2018, 02:13 PM)amator_1 Wrote: wat am i doing wrong?
this is wat i get
:~# systemctl status fanctl
● fanctl.service - Active Thermal Fan Service
  Loaded: loaded (/lib/systemd/system/fanctl.service; enabled; vendor preset: enabled)
  Active: activating (auto-restart) (Result: exit-code) since Sat 2018-09-15 22:10:16 CEST; 1s ago
 Process: 1847 ExecStart=/usr/sbin/fanctl (code=exited, status=127)
Main PID: 1847 (code=exited, status=127)
Can anyone help
Hello amator_1,
If you are in Ubuntu,
You need to upgrade kernel too(Debian Strech also needs kernel update), so that it will export to SysFs the Functionalities fanctl need.
To do so, you can:
apt-get clean
apt-get update
apt-get install linux-rockpro64 -y
apt-get install linux-image-4.4.138-1094-rockchip-ayufan-gf13a8a9a4eee linux-headers-4.4.138-1094-rockchip-ayufan-gf13a8a9a4eee cpufrequtils
Then reboot, and you should be fine.  Shy
Hope it helps
this is wat i get
Can anyone help
Hello amator_1,
Can you post the result of these 4 commands?
ls -l /sys/class/{thermal/thermal_zone{0,1}/temp,hwmon/hwmon0/pwm1}
ls: cannot access '/sys/class/hwmon/hwmon0/pwm1': No such file or directory
-r--r--r-- 1 root root 4096 Sep 21 09:42 /sys/class/thermal/thermal_zone0/temp
-r--r--r-- 1 root root 4096 Sep 21 09:42 /sys/class/thermal/thermal_zone1/temp
ls -l /usr/bin/lua
lrwxrwxrwx 1 root root 15 Sep 21 09:42 /usr/bin/lua -> /usr/bin/lua5.3
ls -l /usr/lib/aarch64-linux-gnu/lua/5.3/sleep.so
lrwxrwxrwx 1 root root 47 Sep 21 09:41 /usr/lib/aarch64-linux-gnu/lua/5.3/sleep.so -> /usr/lib/aarch64-linux-gnu/lua/5.3/sleep.so.0.1
ls -l /usr/sbin/fanctl
-r-xr-x--- 1 root root 8056 Sep 21 09:41 /usr/sbin/fanctl
regards
Hi tuxd3v
I added the results as copy past the questions above.
Thanks for the reply
(09-21-2018, 01:54 AM)Hi tuxd3v Wrote: I added the results as copy past the questions above.
Ok, the problem seems to be related with pwn:
Maybe is exported to SysFs with another name..
Check if it has another names on SysFs
For Example:
find /sys -name \*pwm\*
This is to Find were the pwm is  Shy
regards
While he does not update the kernel, he will not find it.
and the kernel is by ayufan
(09-21-2018, 09:43 AM)romtorwator Wrote: While he does not update the kernel, he will not find it.
Yes its true,
first he need kernel update..
Without it, will not be able to get those Controls via SysFs.
[quote pid='40992' dateline='1537559674']
Yes its true,
[/quote]
Ho do I update the kernel , I use openmediavault  see attachement
(09-22-2018, 03:27 AM)amator_1 Wrote: Ho do I update the kernel
4.4.132-1075 this is the old kernel, it does not yet have this, you need at least 4.4.132-1083, but better current:
sudo apt-get update
sudo apt-get install linux-image-4.4.138-1094-rockchip-ayufan-gf13a8a9a4eee
sudo apt-get install linux-headers-4.4.138-1094-rockchip-ayufan-gf13a8a9a4eee
sudo apt-get install linux-firmware-image-4.4.138-1094-rockchip-ayufan-gf13a8a9a4eee
sudo reboot
or download here and install the packages https://github.com/ayufan-rock64/linux-k...hip-ayufan
sudo apt-get update
sudo reboot
Thank u romtorwator, i will try to update.
SOLVED
Thanks to everybody for the help.
kernel update did the job. Heart Heart Heart
  PWM Fan Control Python Script superbox 0 2,473 02-04-2022, 10:02 PM
Last Post: superbox
Users browsing this thread: 14 Guest(s)
