How can I install tvheadend server un rock64?
(08-14-2018, 03:13 PM)Rocklobster Wrote: Assuming you are using Debian Stretch choose either Doozer or Bintray from this link https://tvheadend.org/projects/tvheadend...Repository
Just read through this link and follow the steps laid out.
Thanks , but in this page, debían is not supported for armhf / arm64.
What can i choose?
Sorry but i’m very newbbie
What can i choose?
You can try out the below method that listed on their wiki page.
Raspberry Pi / Raspbian armhf
Unofficial Raspbian packages are provided by mpmc for both Raspbian Jessie and Stretch.
  • These builds are done manually and may lag behind, however I'll do my best to keep them updated until the official repo is able to provide the packages.
  • There's no transcoding support, mainly because the Pi isn't powerful enough to do software transcoding and hardware transcoding is not yet available.
  • There is no changes to the code whatsoever for these builds.
  • Make sure to enter the distro as raspbianjessie/raspbianstretch and not jessie/stretch.
Usage
To use this repository follow the official usage guide - for bintray, but change the repository URL from https://dl.bintray.com/tvheadend/deb to https://dl.bintray.com/mpmc/deb and replace DISTRO with raspbianstretch or raspbianjessie.
Example:
echo "deb https://dl.bintray.com/mpmc/deb raspbianstretch stable-4.2" | sudo tee /etc/apt/sources.list.d/tvheadend.list
(08-24-2018, 03:29 PM)tllim Wrote: You can try out the below method that listed on their wiki page.
Usage
Example:
Hello i add this to sources.list
And when i do sudo apt-get update , that is the answer
Quote:Reading package lists... Done
N: Skipping acquire of configured file 'stable-4.2/binary-arm64/Packages' as repository 'https://dl.bintray.com/mpmc/deb raspbianstretch InRelease' doesn't support architecture 'arm64'
  Rock64 v2.0 u-boot SPI issues ju0n 0 821 07-05-2026, 11:02 AM
Last Post: ju0n
  Rock64 No Audio @ Debian 12 dmitrymyadzelets 2 6,155 04-08-2024, 06:47 AM
Last Post: dmitrymyadzelets
  OpenWRT on the Rock64 CanadianBacon 14 28,556 04-03-2024, 08:48 AM
Last Post: helpmerock
  Rock64 bricked shawwwn 7 16,860 03-17-2024, 12:22 PM
  Rock64 won't boot luminosity7 10 18,841 03-16-2024, 08:33 AM
  Rock64 doesn't boot dstallmo 1 4,873 03-16-2024, 08:29 AM
  How well does Rock64 deal with HDR and Atmos on Kodi? drvlikhell 3 9,967 04-29-2023, 04:24 AM
Last Post: newestssd
  Rock64 board not working, no HDMI no Ethernet. EDited 3 10,978 01-17-2023, 02:31 PM
Last Post: Flagtrax
  ROCK64 v3 can it boot from USB? Tsagualsa 4 10,355 11-29-2022, 11:31 AM
Last Post: Macgyver
  rock64 v3 spiflash Macgyver 0 4,940 11-28-2022, 02:18 PM
Last Post: Macgyver
