Heatsink for SOPINE
is heatsink available in the store (https://www.pine64.org/?product=rock64pine-a64-heatsink) suitable for SOPINE A64 COMPUTE MODULE? The SOPINE boards will be installed on the clusterboard. Thank you.
Cheers!
Currently with the same issue and I need the GPIO/Control pins for remote control so that makes the space you get real tiny.
I was thinking about getting a plate of some heat dissipating material and cut it up in pieces the size of the nodes and use some sticky cooling paste to stick the 'plates' on the nodes and use a fan on that..
But..
I'm testing here with 7 modules in a board and 1 simple fan that generates airflow between the modules get them from 80c to 40c.
So I'm thinking we are going to place the boards in the datacenter and the airco is keeping it cool so only 1 fan per clusterboard should do it for us.
  Tow-boot on Sopine module? poVoq 2 5,345 04-05-2023, 12:48 PM
Last Post: poVoq
  Benchmarking the SOPINE Modules on the Clusterboard clusterDude 4 11,193 08-20-2020, 12:56 PM
Last Post: xmixahlx
  Sopine Fedora 32 on clusterboard w/networking revoman 0 5,203 05-20-2020, 01:23 AM
Last Post: revoman
  SOPINE LTS Availability and Plan aldrich@tulip.co 0 4,444 05-14-2020, 10:00 AM
Last Post: aldrich@tulip.co
  SoPine eMMC compatibility Terra854 4 12,738 02-20-2020, 07:52 PM
Last Post: mcrognale
  Sopine baseboard CSI port camera not work olivaw 2 6,911 02-20-2019, 09:50 AM
Last Post: maya.b
  Is it Sopine, SOPINE, SOPine or SoPine? Pine 2 8,556 01-07-2019, 08:37 AM
Last Post: Pine
  +SOPINE baseboard datasheet is different gamelaster 3 9,978 09-09-2018, 05:08 PM
  How to control the SOPINE UART and SPI pins as GPIO? Pine 1 5,874 08-22-2018, 10:15 AM
Last Post: martinayotte
  Two of our sopine's only register 1GB RAM paradise 3 8,382 08-09-2018, 08:35 AM
Last Post: paradise
